Price Check price check on jd2320 with 62" mmm, BH, and FEL
   / price check on jd2320 with 62" mmm, BH, and FEL #1
HammA5690
Member
Upstate , NY
Jd 2520
Just a price check on a jd 2320 with a 62" mmm, BH, and a BH. I live in upstate ny about 20 miles from binghamton. Also can the 2320 run full size implements like a brush hog or post hole auger or would I need to buy smaller implements. The tractor will be used for mowing 2 acres weekly and 5 additional about once a month, skidding logs for a wood stove and occasional digging and carrying soil and rocks in the FEL.
Any help would be great.
   / price check on jd2320 with 62" mmm, BH, and FEL #2
The 2320 has a standard Cat 1, 3 point hitch. Can't help with the price but I use a 3 point post hole digger quite a bit; no problems (until I run into large chunks of basalt). If you can swing it get one with down force. I have used both a 5 foot and 4 foot Brush Hog squealer. My place was too rough for the five footer but the four foot works fine. If your land is relatively smooth the 5 foot should work okay but in heavy stuff you may have to either overlap your passes or slow down a bit.
   / price check on jd2320 with 62" mmm, BH, and FEL #3
What is your definition of "full size implements"???
My father in law has a 81" brush hog and finish mower along with a john deere post hole digger not sure what size.
   / price check on jd2320 with 62" mmm, BH, and FEL #5
No way will you be able to run that 81" bush hog. Probably 48" max...
Oh well, I guess that's the benefit of having him live only a few minutes away. He can just drive the tractor over.
   / price check on jd2320 with 62" mmm, BH, and FEL #8
it will run the 81 inch bush hog as long as you not trying to cut a foot of grass at a time.or run over anything.it will run logspliters tillers. blades .sub soilers. snownlowers
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2014 INTERNATIONAL PROSTAR (A50854)
2014 INTERNATIONAL...
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
2018 FORD EXPEDITION (A51406)
2018 FORD...
1268 (A50490)
1268 (A50490)
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
