Preventing rust after welding
/ Preventing rust after welding #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I need to do some minor welding on a galvanized tube fence gate. Yes I am aware of the issues welding galvanized metal. So what is the best way to keep things from rusting once I burn off the galvanizing where I welded it? I would prefer not to paint since that would mean needing to paint the whole gate for esthetics. If I must I will but is there anything else?
/ Preventing rust after welding #2
Would a cold galvanize spray can do any good after cleaning it? Don't know myself, just throwing it out there for discussion.
/ Preventing rust after welding #3
This is the best stuff I have ever used on galvanized material. Apply with a torch, and wire brush in. Acts a lot like solder.
Very pricey tho!
/ Preventing rust after welding #4
An acetylene torch and solder might do the trick since there is about 400 degrees difference in zinc and lead solder melting points.
/ Preventing rust after welding #5
You can get the sticks of zinc like Shield Arc showed or there's a spray on zinc galvanizing by Crown which does a very good job. Most aren't worth what you pay for them, but the Crown brand does a good job.
/ Preventing rust after welding #6
Oh shucks, just brush on Tremclad flat aluminum paint and in about a couple of weeks you'll never know it was welded.
Wire brush clean first and if you paint it on while the metal is still hot it will be 'baked on'.
/ Preventing rust after welding #7
Cold gal spray paint is excellent. It is what is used and recommended by communications tower manufacturers for touch up.
As mentioned the Crown brand is very good although harder to find than Rustoleum, which also works almost as well.
I've used a lot of it over the last 25 years and always had great success with it.
/ Preventing rust after welding #8
Skyco, is this the one you are recommending? ::: White Knight Paints
/ Preventing rust after welding #9
I'm not familiar with the White Knight product. The Rustolium is easier to find as Skyco said and is pretty good. I still think that Crown is about the best there is though outside of using a zinc stick applied with heat.
The biggest trick with Crown is always turning the can upside down and clearing the tip after using or it is guaranteed to clog the tip.:laughing:
Aervoe 7007 Cold Galvanizing Compound-Spray Can
http://www.capital.edu/15621.pdf
/ Preventing rust after welding #10
I used to work for a company that specialized in galvanized farm gates. They'd weld the galvanized material, then they'd use the cold galvanized paint to touch up the weld area. It did work, and it lasted for some time.
/ Preventing rust after welding #11
I've had that trouble with just about every cold gal paint I've tried...the White Knight stuff in a bulk can might be just the ticket, use a disposable brush then chuck it:thumbsup:
I assume you've also noticed the nozzles on cold gal sprays have a much larger orifice than regular paint nozzles...kind of interesting if you get one mixed up and put it on a regular paint spray can....be ready for some high speed painting:laughing:
/ Preventing rust after welding #12
Never noticed the larger nozzle orifice. I have noticed that most brands spray about like water though. You have to spray the Rustolium or Crown pretty thick to even begin to have to worry about runs. Just too thick.:laughing:
/ Preventing rust after welding #13
Another possible option is to spray it with clear enamel just to stop the rust.
Aluminum colored paint is a pretty decent choice, too.
Neither one is a perfect match.
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
JOHN DEERE 7410 TRACTOR (A64278)
JOHN DEERE 7410...
2001 Ford F-250 Pickup Truck (A64556)
2001 Ford F-250...
UNUSED KJ K2010 HEAVY DUTY CHICKEN COOP (A65055)
UNUSED KJ K2010...
SKID STEER FORK (A64553)
SKID STEER FORK...
TIGER MOWERS TRF102-102" REAR FLAIL MOWER (A63276)
TIGER MOWERS...
