RayCo
Veteran Member
- Joined
- Jul 24, 2005
- Messages
- 1,039
- Location
- Chester County, PA
- Tractor
- Kubota BX24, Case 580 Super L
Where I live, the only flat area on my property is my garage. So, I always need to plan out my tractor traveling based on what hills I'll encounter and what kind of loads I have. There have been a few times that I've been going through an area slowly and found myself on three wheels.
What I've done a number of times is swing the backhoe to shift some weight to that side, and I also lower the stabilizer on the side where the tractor would roll if it decided to and just keep it a few inches off the ground as I creep my way out of the situation. If the tractor were to actually pass its tipping point and decide to tip over, would the stabilizer stop it, or am I actually creating a more dangerous situation by not letting the tractor tip over in a uniform way? I tend to think that it'd stop it, if it's a slow tip, but since I've never seen the stabilizers mentioned in the rollover threads, I figured I'd ask opinions.
There are two things that I know are just a matter of time until they happen: a tree will fall on my house, and I will roll my tractor. I look forward to neither event.
