Prest-O-Lite W-250 Torch
   / Prest-O-Lite W-250 Torch #1
YardBikeBob
Missouri Ozarks, Booger County
LS R4041H
Scored an Oxy-Acetylene rig to compliment my wire welder. Motivation was to be able to heat & bend metal besides just welding.
It came with a Prest-O-Lite W-250 torch with a #6 tip as well as a cutting attachment.
What it did not come with was a rosebud for heating metal.
Alas, the HF Rosebud is not compatible with this torch.
So now my questions:
  1. Anything special about this torch? Is there some 'industry standard' verbiage for specifying tips compatible with it?
  2. Should I buy another torch to be compatible with a 'standard' rosebud? I suppose HF has torches, too.
  3. For welding wire, I bought some from HF labeled for Tig welding. But it'll be fine for gas, right? (Little short on metal coat hangers.)
  4. Regulators are labeled 'Wika' and I don't know anything about that brand either.
  5. Should I expect any surprises (on providence) when I eventually have to refill these tanks?
  6. How much should I expect refills/exchanges to cost?
The rig came from an estate sale within the family. Thanks in advance!
~Bob
   / Prest-O-Lite W-250 Torch #3
I don’t see a cutting torch in the photos. Did I miss something
Another question.....
With the Acetylene set at 6psi and the tank gauge showing 210psi (of 400 max) I can hear sputter, see droplets, and smell acetone. Is it time to refill the tank?
Also, the Oxygen tanks is showing 900psi (of 4000 max). Is it also about done?
~Bob
   / Prest-O-Lite W-250 Torch #6
I can get tips for my victor torch on ebay for $5 a piece, the rosebud is like $10. these are all "compatible tips" not the expensive Victor tips.. your brand seems to be too old to get tips.. unless it's used for soldering or brazing that is.. that is what that company is known for.. and YES, I did a lot of searching trying to find a rosebud tip for that torch..
Thanks for feedback. I also failed in the search. Didn't know if the Prest-o-lite W-250 was an off brand, just too old, or Google didn't feel helpful today.
~Bob
   / Prest-O-Lite W-250 Torch #8
~Bob
DANGER! what you are describing is what happens when you try to get too much flow from an acetylene tank!:eek: you really don't want an explosion, or damage your setup right?. you can only draw 1/7 of the cu ft at most from the acetylene tank, it must be a small one!!..
DANGER! what you are describing is what happens when you try to get too much flow from an acetylene tank!:eek: .... it must be a small one!!..
The 8.5" diameter tank is 32" tall. The gauge is showing 210psi in the tank and the torch was drawing 6psi on the gauge. Hence my confusion.
   / Prest-O-Lite W-250 Torch #10
I have the same torch gotten from CL. It came with a #4, #9, and #15 tip plus same cutting torch you have it looks like. For bending and heating I use the #9 or cutting torch w/o Ox. works fine. Your so called #6 might be a #9 which is a standard. Read the number with the tip pointing up. The numbers are cubic feet of Acetylene per hr. Make sure you know your tank size and understand the 1/7 to 1/10 withdrawal rate of the Acetylene limitation. It doesn't sound like the tanks are empty. you might want the regulators checked out.
gg
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2017 MITSUBISHI OUTLANDER SPORT (A52472)
2017 MITSUBISHI...
Generac Generator (A51691)
Generac Generator...
12 in Large Excavator Bucket (A52377)
12 in Large...
2011 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2011 FREIGHTLINER...
