Pressure Washer Water Temp & Degreaser
   / Pressure Washer Water Temp & Degreaser #1
fidowanttobe
Platinum Member
Mandan ND
Jinma 284 2007 Massey Harris 44 Special
Greetings,
I need a second opinion,
I picked up a fitting at a pressure washer repair house and asked him how HOT the water can be going into my COLD water washer. To my shock he said "Your safe up to 140°"!!! That is what my water heater is set at, as in HOT water I said. "Yup, no problem".
So, while I do mix c&h, I've never ran all hot. My Massey has a 40 year old oil film that won't give in. Would you guys run 140° in a 20 year old Craftsman PW?
Also, what is your favorite degreaser? Wallmart foaming engine in a spray can ain't doin it.
   / Pressure Washer Water Temp & Degreaser #2
I can run hot water through my 20+ year old Handy power washer, it's electric. But the owners manual warns me to grease the pump before I do. It has a grease zerk that gets greased every now an then when using cold water. If you can't grease yours, I wouldn't use hot water very long and not to often.
   / Pressure Washer Water Temp & Degreaser #3
I never tried hot water into any of my PWs. Maybe I will now. No grease fitting on the pump,
however.
None of the foaming aeresol engine degreasers work anymore, from my experience. Changes
to the formulas maybe 15y ago ruined them. Nowadays, detergent may be the only thing you
can use.
   / Pressure Washer Water Temp & Degreaser #4
I have a double bib into my garage that goes into a 2 into 1 washing machine adapter hose It lets me use the water from my domestic hot water tank when I want / need it. Actually I seldom use it as the cold seems to do the deed well enough for most things.
As for the 4o year old grease film I think if the pressure didn't do it then it's time to break out the solvent, old paint brush and pack of small brushes. Sit down and attack it then blast , then attack then blast till you get it clean. That pin point nozzle puts out a lot more pressure than the fan style but you have to be careful not to knock the paint off. Plastic putty knives and even the good old M1A1 steel brush you get for $1 work well to scuff up the hardened on crud.
The best degreaser I ever found to use by hand is good old gasoline, (que the safety police:rolleyes:) Carburetor cleaner seems to work quite well too. Just use common sense, hand powered brushes ect only take the usual precautions and do it outside. The crud will come off fairly easily with the water blast once you rough it up enough.
   / Pressure Washer Water Temp & Degreaser #5
I bought a gallon of WD40 and used it in a spray bottle and hand wiped it off. It did a pretty good job of cutting through the grease.
   / Pressure Washer Water Temp & Degreaser #7
WD40
Spray it everwhere. Let it sit for a bit, and then wash with whatever poor excuse for a soap you can get for your pressure washer.
The WD40 seems a little less harsh than gasoline or many other solvents, yet still works well. Brushes help lots with any degreaser.
   / Pressure Washer Water Temp & Degreaser #8
And yes, I would run household hot water thru any pressure washer.
Probably going to be doing just that again soon...
   / Pressure Washer Water Temp & Degreaser #9
I agree that diesel makes a very good solvent/cleaner for many things, but IMHO mineral spirits work the best. I keep a couple of little squeeze bottles with a flip-up spot in several places.
   / Pressure Washer Water Temp & Degreaser #10
No contest! But when you have a large job to do, mineral spirits gets expensive.
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
UNUSED INDUSTRIAS AMERICA L6 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
