Pressure Washer Use in Winter
   / Pressure Washer Use in Winter #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I am interested in using my pressure washer this winter. I usually winterize it.
Here in NJ my attached garage gets in the mid 30s often.
Has anyone built something to keep their pressure washer heated, instead of heating the entire garage?
   / Pressure Washer Use in Winter #2
Just flush it with rv antifreeze when your done using it. It takes 2 min. I have 2 for about 15yrs now
   / Pressure Washer Use in Winter #3
What are you using the pressure washer on (ie:car)?
I’d be more concerned about the water/spray freezing up where it was used, like in the driveway.
To answer your question though, can always use one of those turbo blower heaters that are powered by diesel/kerosine. I use one to thaw out my skidsteer occasionally; works great because it’s forced hot air right where i want it.
   / Pressure Washer Use in Winter #4
It should be relatively easy to keep a small space above freezing if it's within an attached garage. A plywood or cardboard box placed overtop of the washer, with either a heat tape or small light bulb inside should be plenty to keep it above freezing.
   / Pressure Washer Use in Winter #5
A heated pet mat (or whatever they're called) under the washer and a large box as suggested in the post above.
   / Pressure Washer Use in Winter #7
   / Pressure Washer Use in Winter #8
Back to the box idea, I think it would likely work with no heat source in the right location of the garage. My insulated but unheated attached garage gets below freezing at times, but I store potatoes and onions in there with no issue. I store them close to the house wall and have them lightly covered with a box or rug. There's enough warmth from the house wall and the basement (floor of garage close to the house) to keep that area above freezing. Put a thermometer on the floor to get a better idea if that will work. Cover that with a box and monitor your temps. If a cardboard box works, you could make one out of foam board for even better protection.
   / Pressure Washer Use in Winter #10
Also there exists small magnetic heaters @ a few 100 watts that could do the trick.
Not pricy either.
Perhaps slap it on and maybe toss an old carpet to keep in the heat.
Useless to heat my CUT but would do OK on a washer.
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
2006 Nissan Titan Crew Cab Pickup Truck (A55788)
2006 Nissan Titan...
Bush Hog 9670 8FT Pull Type No Till Grain Drill (A55218)
Bush Hog 9670 8FT...
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
2019 FORD F150 TRUCK (A51406)
2019 FORD F150...
