pressure relief valve B7800
   / pressure relief valve B7800 #1
atgvir
Virginia
Kubota L4240 HST
Could some one please tell me where to locate the pressure relief valve on a B7800 for the lift hydraulics. Also, does any one have the range the hydraulics can operate in on the 7800. I want to increase my lift capacity on the la402 loader and don't want to exceed the max. pressure. I plan on using a gauge and changing the shims to get max pressure.
Thanks,
Please guys. Anyone out there that has a service manual for the 7800 that can look up the pressure range on the hydraulics for the 3pt hitch and loader.
Thanks,
   / pressure relief valve B7800 #3
Thanks,
The relief is in the pressure control valve. The relief setting is 1920-1991psi according to the service manual, so that must be the max pressure.
Thanks so much. That is what I needed.:D
   / pressure relief valve B7800 #5
Here is the parts list for your loader. Hope it opens.
  • B7800 LA402[1] Loader Parts.pdf
LeeJohn,
Thanks for the parts manual. Does any one know if the relief valve for the 3pt hitch also control the loader. I have the parts manual for the tractor and did find the valve for the 3pt hitch. I have read that most Kubota tractors use the same relief valve for the 3pt hitch and front loader.
Thanks
   / pressure relief valve B7800 #7
Look on page 126 and 127 of your parts manual and see if that tells you anything.
   / pressure relief valve B7800 #8
LeeJohn,
Thanks
Based on my admittedly elementary understanding of hydraulics, it would seem dangerous to not have a pressure relief valve on every control valve. My reasoning is that if you were operating the loader, there would be no flow through the power beyond port to the 3pt, so that relief valve could be of no help if the system over pressurized.
UNUSED CFG QUICK ATTACH HYD POST DRIVER (A51248)
UNUSED CFG QUICK...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
New/Unused 250 PVC Safety Traffic Cones (A51573)
New/Unused 250 PVC...
2022 KMC 5610 LOT NUMBER 212 (A53084)
2022 KMC 5610 LOT...
