Pressure releif valve - front loader - Iseki 1240
   / Pressure releif valve - front loader - Iseki 1240 #1
Marcle
Herefordshire/Gloucestershire boarders UK
Iseki 2140
Hi guy's,
I'm the new owner of an Iseki 2140, so trying to workout where everything is.
I'm looking for the locations of the pressure relief valves on the hydraulics for my front loader. I've found the PRV on the control spool valve, however there must be another on the tractor somewhere, can anyone advise please?
Thanks in advance of any help.
   / Pressure releif valve - front loader - Iseki 1240 #2
Hi guy's,
There should be a relief valve for the 3pt and one for the FEL valve.
On the FEL valve, it is usually close to the IN port.
Hi,
If you mean the one on the up/down levers (spool valve), I've already found that one, but there must be another somewhere on the tractor it self, or have I miss-understood you?
   / Pressure releif valve - front loader - Iseki 1240 #4
Hi,
If you have a FEL or loader, that valve will have a relief valve.
The 3pt always has a relief valve.
If you have a remote valve, it will have a relief valve.
Here's a photo of the one on the frame of the front loader
   / Pressure releif valve - front loader - Iseki 1240 #6
There should be another relief valve in the 3pt area. You should obtain a parts manual for your tractor.
Hold your 3pt handle up to raise and you should hear it scream, and it will be relieving fluid to the tank, and if you install a hyd gage in the hyd system, you can see and perhaps set the relief pressure.
I have previously put out a request for manuals.
There is no sounds of any prv's blowing off when the 3 point linkage is raise to max, nor change in engine tone.
   / Pressure releif valve - front loader - Iseki 1240 #8
All reliefs don't make sound, but most do.
Install a hyd 3000 psi gage in a tee at the IN port of the FEL valve and you can see the pressure of any hyd component using the hyd.
Well.... finally got a pressure gauge set up, and the result was disappointing, but plenty of room for improving as the max pressure was a touch over 1500psi. I've not done any further investigation yet, but hoping the PRV is the problem as the tractor has only done 208 hours.
   / Pressure releif valve - front loader - Iseki 1240 #10
1261 (A50490)
1261 (A50490)
2014 PJ TRAILER 40' TANDEM AXLE GOOSENECK (A52472)
2014 PJ TRAILER...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
