Pressure Gauge Question
   / Pressure Gauge Question #1
NCMau
NC
MF 202/Ford 8N
I am in the process of modifying my tractor with a PTO hydraulic pump. If I were to install a permanent pressure gauge in the system, would the inlet of the control valve with a T be a good choice?
   / Pressure Gauge Question #2
That would be the perfect place for it. Be sure to use a Tee rated for the pressure (and not a cast iron plumbing one from Home Cheapot) and gauge rated for 3k or 5k PSI.
   / Pressure Gauge Question #3
liquid filled gauge too!
   / Pressure Gauge Question #4
As kennyd says get 3-5K psi guage. It is said a guage is most accurate in the center of it's range, hence if you expect 2500psi get a 5Kpsi guage. On the other hand the graduation will be further apart on a 3Kpsi gauge than a 5Kpsi guage so it might be easier to read. Either will work.
Thank you guys. I am totally redoing the loader hydraulic and I am surely going to have more questions in the near future. One that comes to mind is the drainage of the external tank (located behind the seat). Although not absolutely necessary, I am thinking it maybe important to have one to avoid uncoupling the lines for fluid drainage purpose. Maybe T the return port of the tank?
2011 DOOSAN G25 GENERATOR (A53843)
2011 DOOSAN G25...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
2002 MACK RD688S ROLLOFF TRUCK (A51406)
2002 MACK RD688S...
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
2005 CHALLENGER 500 BBL FRAC TANK (A53843)
2005 CHALLENGER...
