prepping for spring work
   / prepping for spring work
M&W kits were real common. I'd think any turbo rebuilder could get him a donut. Not sure if the one from a 7000 will work.
Soundguy
   / prepping for spring work #12
Soundguy
It is not a doughnut looks like 2 little top piston rings. seals between the outlet of the turbo and the exh elbow.
Been wondering if a briggs piston ring would work :)
Ben
Oh, like a crushable compression washer?
Soundguy
   / prepping for spring work #14
Like 2 piston rings with fiber on the flats in between them. Yes sort of like a super duty compression gasket/washer. They look just like Briggs compression rings with something in between them.
Actually I think rope type heat proof caulking rope would work if there is such a thing. It is a low pressure application with only the backpressure of an open stack on them. I think they just allow for mismatched expansion of the trubo outlet and the elbow that points the stack vertical.
Ben
Btw going tomorrow to get my oil and filters for spring prep.
Rope type stove gasket is available at most good old fashioneed mom-n-pop hardware stores..
Soundguy
   / prepping for spring work #16
Thanks soundguy, that might just work, if not it will just blow up the stack.
Ben
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59575)
2007 FREIGHTLINER...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2017 FREIGHTLINER...
2022 John Deere Z930M (A57148)
2022 John Deere...
2021 KOMATSU WA200-8 WHEEL LOADER (A60429)
2021 KOMATSU...
