Preparing big area for sod, Which attachment
/ Preparing big area for sod, Which attachment #1
johndeerescout
John Deere 3032E
This is my first post here and if someone has already posted about this, please give me a link.
I own 14 acres and own a JD 3032E.
I have a pretty good size front yard. I ended up having to dig up and replace a gray water line, which ended up being around 200' and how they had it laid made no sense at all. I ended up getting to a good spot on the line and replacing 100' and covered it back up, but that part of the front yard is messed up. I have a little more work to do before it all is level out how I want it.
MY QUESTION: We are going to be adding sod to a very large area and wanted to know what attachment would work best for preparing the soil?
renting a small garden tiller, I believe, would take a long time because of the amount of area needing prepared.
I would love to buy a tiller for the tractor, but I do not think the wife will go for that. I do believe a tiller would work best and could also use it for small jobs for people needing someone that has a tiller.
I've been looking at a disc harrow (a good used one) and believe it would be the best attachment for the job, but just wanted to ask for advice to see if my thinking is is correct.
I also have an arena that gets weeds growing up in it and thought that a disc harrow could be used for the purpose of those down also, so buying a disc harrow would be an investment for keeping the arena looking good.
Thanks for any help and hope that I gave enough information to get my question answered.
ASh
/ Preparing big area for sod, Which attachment #3
Have you checked the price of sod? If a tiller isn’t in the cards this project might be over before it started. A rock hound on a skid steer is the ultimate tool. But serious $$. A Harley rake is the next best. A tiller with a lot of hand debris removal will get the job done. I usually use my Mule to roll the tilled areas back down. It doesn’t cause the ground compaction other equipment does but its enough to mostly prevent erosion.
/ Preparing big area for sod, Which attachment #4
I have a harley rake. No tool better. Some rental houses do have them. There are 3ph and SS models. Woods makes a similar rake.
/ Preparing big area for sod, Which attachment #5
When I crop rotate from corn to hayfields, I just use a plow and a log cut from the woods.
By deep plow with a land plow, it loosens the soil. Then I take the biggest, longest log I can drag through the dirt, and then grade the area.
The log pushes the rocks into the soft soil, but also compacts and smooths the surface of the land. The longer the log, the smoother the field because it cuts and bridges holes and such. Just keep dragging it over the area many times and it will get more and more smooth, picking out the rocks each time you go over it.
I used a skidder to pull my logs in doing this particular field, but it is whatever your tractor can handle.
/ Preparing big area for sod, Which attachment #6
Specs show that tractor with a 58 width, so you'd need a 60" tiller at a minimum. No idea what rentals might cost but a good quality rear tine walk behind tiller could run close to a grand. A 60" 3 point tiller might be close to double that, but could be somewhat less on sales and coupons/promos. That plus a landscape rake will do most of the job with far less aggravation than a walk behind.
And then there's always the possibility of hiring out some work to neighbors to help pay for the toys ... err, tools.
/ Preparing big area for sod, Which attachment #7
Will a tiller work for the arena area?
Any thoughts of seeding instead of sod?
/ Preparing big area for sod, Which attachment #8
You could kill everything, then disk it up fine. And then plant Bermuda seed. Get good seed from a respected seed company.
Bermuda is better IMO because you can put different weed killers on it and it will survive.
/ Preparing big area for sod, Which attachment #9
Preparing the dirt for sod or seed is just the first problem. Next is how are you going to keep the wide area watered? I googled how much water is required to start a sodded lawn and got that you need to water 3 to 5 times a day during the first 7 to 14 days and for a seeded lawn, only slightly less.
You also should get some soil analysis done to determine if the soil needs any remediation too.
Exact requirements will vary for location which you did not provide. Your county extension service is a good source of information and may even provide soil analysis service.
If you can't water the whole area that much, you are wasting your money on materials. Maybe consider starting with a smaller, more manageable area near the house first and work your way out as you get established.
/ Preparing big area for sod, Which attachment #10
Harley rake on a skidsteer ...game over.
/ Preparing big area for sod, Which attachment #11
Tiller does not leave smooth bed for grass.
Transition areas between new and existing can be difficult with sod. Easier to plant seed next to existing grass
/ Preparing big area for sod, Which attachment #12
I "redid" a one acre meadow right at the end on my driveway. Just too many weeds. I mowed it with my JD G100 riding mower. Sprayed it with RoundUp. Disked with with my 3-point disk. Drug it smooth with my home made drag - picture of drag below. Then seeded it. It took a year but now I have a great meadow with mixed types of field grasses.
Have you checked the price of sod? If a tiller isn稚 in the cards this project might be over before it started. A rock hound on a skid steer is the ultimate tool. But serious $$. A Harley rake is the next best. A tiller with a lot of hand debris removal will get the job done. I usually use my Mule to roll the tilled areas back down. It doesn稚 cause the ground compaction other equipment does but its enough to mostly prevent erosion.
Yes, we are are getting 15 pallets of St. Augustine, brought in on Sept 6.
ASh
We are doing St. Augustine to match the rest and they do not sell it in a seed.
ASh
UPDATE:
Well I got a disc harrow for really great deal and will be using it.
We are doing St. Augustine sod, getting 15 pallets of sod.
It came out to around 6,500 sqft.
Thank you all for your help.
ASh
/ Preparing big area for sod, Which attachment #16
Better get a landscape rake to go behind that disc harrow with.
2014 JLG 10054 SKYTRAK TELEHANDLER (A60736)
2014 JLG 10054...
2006 Freightliner Auger Truck (A61307)
2006 Freightliner...
Godwin CD150M Dri-Prime Towable Trash Pump (A61567)
Godwin CD150M...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pick-Up Truck (A60352)
2023 GMC 1500...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
