prefered spare tire mount
   / prefered spare tire mount #1
schmism
Super Member
Peoria IL
New holland TC(33)
need to build a mount to hold a spair for my new trailer.
were do you like your spare?
on the front
on the tongue
on the side
under the bottom
other?
would be hard for me to mount to the front because the trailer already has a tool box welded to the front.
i could see issues with the side with loading stuff from the side
i could see issues with the touge in reducing how sharp a turn you can make
i can see issues with under the bottom with maintance and access.
   / prefered spare tire mount #2
Both my dump and small utility trailers had them mounted on the right front corner.
If you are concerned about loading from the side, you could still mount it on the front corner using a swing away carrier like on the back of a Jeep, and just swing it out of the way when side loading. Wouldn't be that hard to make, or you might find one on CL, or ebay.
   / prefered spare tire mount #3
on one I hace a spare mounted to an upright piece of angle on the front corner of the trailer with a flat plate on it and a coule studs thru with 'spare' lugnuts on the studs.. this gives you spares if you loose them.
on my larger trailer I throw it onto the 'v' rails of the tounge and holed it down with a tab on the tounge sticking up thru the hub hole, then another rtetainer plate, then a pin or lock depending on what area of town I'm in.. :)
soundguy
   / prefered spare tire mount #4
I like the right front corner. On both my boats and also my utility trialer they are right in front of the fender.
I made the one for my utility trailer out of a piece of 2x2 tubing 1/4" wall, 1/2" thick piece of maybe 8"x8" plate, and 2 studs and lug nuts.
Chris
   / prefered spare tire mount #5
If you can't/don't want to move the toolbox to mount the tire under it, put it in the bed of the truck. Everything else is in the way. I put one on the drivers front side that worked ok (it is a low wall box bed trailer). Since you rarely need one (hopefully) that leaves the off side (from traffic) of the trailer available for easier access to check loads, etc. And the spare is less accessible to thieves. You might even give it a thump occasionally as you pass it going to the drivers seat. Underneath the frame works if you keep enough tools around to get to it if you have a flat and a load (right....).
   / prefered spare tire mount #6
"would be hard for me to mount to the front because the trailer already has a tool box welded to the front."
I will be having the same issue.
"If you can't/don't want to move the toolbox to mount the tire under it, "
mojo, could you elaborate a little more on this? Do you mean hanging the spare under the tongue, or are you thinking of something else?
I have a couple of boat trailers and the spare is mounted on the side of the tongue, which works fine for them, because they are very narrow in the front. However, I'm afraid if I try that on a flatbed utility, I will be getting into the spare with the rear bumper of the truck in tight turns.
I am thinking of making a removable holder that fits in one of the stake pockets.
   / prefered spare tire mount #7
Remember if you have a spare you are only 1/2 the way there. I get 5 or so calls a year from customers with a flat that do not have a jack to lift it or the proper sized lug wrench.
I carry a 6 ton bottle jack and a folding 4 way lug wrench. You can get both at your local WalMart for under $30.
Chris
   / prefered spare tire mount #8
I hear ya Chris, be prepared.
In addition to a complete toobox, I carry a floor jack, extra wheel bearings, extra hub, grease gun, tire plugs and a 12 volt compressor.
Chris
do those people not have jacks that came stock with the tow vehicle?
I was considering one of the drive on tandem jacks. anyone use one before?
   / prefered spare tire mount #10
They tend to skid around too much...not a good thing if you are on the shoulder of the interstate...get a decent bottle jack and folding 4-way lug wrench...a couple of scrap pieces of wood can come in handy for a pad or a scotch block, as well.
2018 Challenger 1042 Tractor (A53342)
2018 Challenger...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
FRONTIER WR3212 LOT NUMBER 57 (A53084)
FRONTIER WR3212...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
