Powershift Squeal
/ Powershift Squeal #11
After reading back I thought he said the Tran. Quit. :confused2: And the more I read the details of the problem it sure sounds like the Clutch is just Rusted and Stuck. And IMO. if you drain the Hyd. Fuid it will look like Milk and then that will just about assure you of the Clutch Rusted and Stuck.
You are absolutely correct the clutch is working it is engaging but I cannot disengage it. I checked the fluid level and it is a little over full so I will use a turkey baster to hopefully take some of the fluid out and try it again to see if it still squealing. I use the tractor for couple of hours today to mow down some brush but believe it or not I never pushed the clutch in.
May want to start useing the clutch and try to get it to free up.
GENIE SUPER LIFT CONTRACTOR (A60736)
GENIE SUPER LIFT...
2007 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2007 JLG 600S...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59231)
iDrive TDS-2010H...
Traxmax 300 Stand-On Tracked Sod Installer (A59228)
Traxmax 300...
24in Digging Tooth Bucket Excavator Attachment (A60352)
24in Digging Tooth...
John Deere 4044M (A60462)
John Deere 4044M...
