Backhoe powering a backhoe from the power beyond
   / powering a backhoe from the power beyond #1
cummins666
i have a woods backhoe that i am going to be mounting on a kubota L3710. a dealer tells me that all i have to do is to take the power beond connection going to the loader apart and series the backhoe connections with it. he said the PB is marked green. i was able to find this and it looks easy to do. is this the best way to go?
thanks
ron
   / powering a backhoe from the power beyond #2
Yes, provided the tractor hydraulics have enough flow to power the hoe. Else a PTO mounted pump.
jb
   / powering a backhoe from the power beyond #3
I run a Rhino 85 BH on my L5030HSTC in that manner. Zero problems.
   / powering a backhoe from the power beyond #4
Using the power beyond is probably the best/most cost effective way to power your hoe, just make sure you do not start the tractor with the PowerBeyond "loop" disconnected or you can damage your hydraulic pump.
   / powering a backhoe from the power beyond #5
Power beyond is a good option simple solution, but as others said make sure you always close the the hydraulic loop and as with all hydraulics keep the connectors free of dirt.
2018 CHEVROLET SILVERADO 2500HD (A53843)
2018 CHEVROLET...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
66in Bucket Skid Steer Attachment (A55851)
66in Bucket Skid...
Club Car Utility Cart (A55853)
Club Car Utility...
KMC 5610 (A53084)
KMC 5610 (A53084)
