Powerhorse 3pt Log Splitter and BX23?
   / Powerhorse 3pt Log Splitter and BX23? #1
vrman
Joliet, IL
Kubota BX23 & ZD326P
I'm checking out the log splitter from NorthernTool. I was just wondering if anyone had any experience hooking this up to a BX23 and what I might need or run into?
Thanks!!
   / Powerhorse 3pt Log Splitter and BX23? #2
   / Powerhorse 3pt Log Splitter and BX23? #3
I am also checking out the 13 ton model for my BX25, from what I saw it had decent reviews and people were pretty happy with it even though the cycle time may be a little slow but it splits in both directions to make up for that.
I spent all morning looking through the posts on hooking up splitters in general and the only think I am a little confused on is which 2 of the 3 hydraulic lines I hook into on the back, I am guessing the supply and the PB and the middle one just stays capped.
Oh! I didn't even realize they had 2 models! :D
So what determines which size you should get? 13 vs 20 ton?
Oh I see now. Cylinder size is bigger, so it can do larger cut logs. Cool, I can go with the smaller one.
So from what I read then, I just need to get some hoses made and just hook them into my two hydraulic connections for the BH. Simple! Oh, anyone know what size connectors I need to connect to the BX23?
Hey look, I found that too! ISO 7241 series B.
Ok, last question, anyone know a good place to get the hoses made? (and what type of hose?)
Thanks!
   / Powerhorse 3pt Log Splitter and BX23? #5
Thanks!
Any industrial hose supply in your area....They make air, hydrualic hoses on the spot...Just bring them your fittings...
You can order hoses from Surplus Center online, by the foot, 3000# 3/8 lines will be fine. Make sure you order correct thread for the splitter 1/2 with 3/8 reducer bushings, I think, and the other end to fit your couplings
   / Powerhorse 3pt Log Splitter and BX23? #6
Should be PB and a return line I think...Check your manual or your service center..
BTW, where in NH???
   / Powerhorse 3pt Log Splitter and BX23? #8
you are welcome to come try the splitter if you want...Still mounted, and I'm sure I can find some logs...
   / Powerhorse 3pt Log Splitter and BX23? #9
Thanks!
Most auto parts stores can make them. Check around to get the best price. If you go with the smaller splitter it will speed up your cycle times. You may not be able to split a log down the middle but I would expect you can just split off quarters until it's small enough.
   / Powerhorse 3pt Log Splitter and BX23? #10
It splits 28" oak down the middle fine...
2013 Mack GU713 T/A Roll-Off Truck (A50323)
2013 Mack GU713...
Montreal ST225/75R15 Trailer Tires (A50322)
Montreal...
2009 Chevrolet TrailBlazer Multipurpose Vehicle (A51694)
2009 Chevrolet...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
