PowerARC 300
/ PowerARC 300 #1
DXN1EL
Texas
Hey guys, I place an offer for the Everlast PA-300, and ten minutes latter I got a call, saying that my offer was accepted :thumbsup:
Now I need some rods, :cool2:
/ PowerARC 300 #4
You'll probably pay through the nose at Home Depot. Check around for prices. You might not need 50 lbs. of rod. I'd get some 6010 and 7018.
/ PowerARC 300
Does all of the circuit beakers are the same? I mean, is there a specific breaker for a specific panel?
What size of breaker does the PA-300 need for maximum performance?
/ PowerARC 300 #7
The breaker has to match the brand of panel.ie: Square D, SquareD Homeline, Cutler Hammer, more. Look at your panel. The brand will be on there somewhere.
/ PowerARC 300
10-4:)
/ PowerARC 300
Thanks Mark for the link, Can't wait for the welder to arrive. I need to wire the 50Amp outlet, get a plug and some rods.
/ PowerARC 300
I finally got the time to wire the 50Amp Outlet, I went to Lowe's and I got some Lincoln 7018. I need a lot of practice and scrap metal the Hot Start is very nice I didn't stick the rod at all:cool:, I only got a few pieces of pipe laying around so I did not burn more than 2 rods.:(
I'll see if I can buy some metal on Monday.
/ PowerARC 300 #13
How were the restarts with the 7018? Did you have to knock off the flux kernel on the tip of the rod when restarting or did the Hot Start burn right through it?
/ PowerARC 300
Yea the Hot start burn right through. it felt really smooth restart.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
832743 (A61166)
832743 (A61166)
SCAN TO RECEIVE TEXT UPDATES (A62129)
SCAN TO RECEIVE...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2013 Ford F-250 Crew Cab Diesel Pickup Truck (A61568)
2013 Ford F-250...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
