power washer
/ power washer #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I try to stear clear of the box stores as much as possible. I was in Home Depot yesterday and say this power washer. It has the Honda GX engine and a Cat pump. My old man is looking for one, what do you guys think. power washer sorry guys i cant get the link to work. it is the 6.5 hp Excell 2800 psi, its under outdoor power equip
/ power washer #2
Get the 3200psi.It has athermal dump valve.I've got both and the bigger one is so much better
/ power washer
what is a thermal dump valve?
/ power washer #4
My neigbor and I have the same unit. He uses his much more than I do. It is powerful and reliable. I was careless and broke the connector for garden hose after using it one time. There is a repair center close to my home. Picked up the part next day. $37 for a brass piece that should be about $15. Other than that it is a great unit for its size. Should last for years with proper maintainace.
/ power washer #5
</font><font color="blue" class="small">( what is a thermal dump valve? )</font>If you idle a presurer washer to long the water heats up in the pump and ruins it .Usually bigger units have a vavle the dumps water at regular intervals so there is cooler water in the pump
2022 CATERPILLAR 259D3 SKID STEER (A65053)
2022 CATERPILLAR...
2020 Kenworth T680 Sleeper (A62613)
2020 Kenworth T680...
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
Case 1845C Skidloader (A66285)
Case 1845C...
JOHN DEERE 220 - 18' DISC HARROW (A64277)
JOHN DEERE 220 -...
Arrow Board (A62613)
