Power-trac truck
   / Power-trac truck #1
agjones
Platinum Member
Jessup Mill, NC
Rk55HC, Kubota kx040, power-trac 425d, Bobcat L23, Yanmar 401w, bx1880, IHI 30 and Fiori D40 dumpers, Magnatrac mh5000, Dew-eze ATM72LC Slope Mower, Terramite t6 4wd, DR Power brush mower
This retired uhaul truck got a bridge here in NC that w call the can opener. Now, box cut down, I have a 26'bed that'll haul two 425s or as in the pic a 425 and terex pt30....plus a few attachments. The blue on the far side is half an 11' utility bed used for tool storage. 20200507_181944.jpg
   / Power-trac truck #2
Looks good!
Run what cha brung!
   / Power-trac truck #3
Nice! I see those u-hauls and similarly school buses used by landscapers. Some leave a bit of the bus as a storage shed.
I just have an 18' car hauler that'll haul my PT425, 60" finish mower, 48" brush cutter, two buckets, pallet forks and snow blade all at the same time. :D
   / Power-trac truck #4
That's a crazy looking rig, but ultimately, very efficient. My pickup and trailer has a smaller bed length, lower weight capacity and is probably long in total length.
   / Power-trac truck #5
I wonder if someone borrows it someday and discovers that the missing roof and sidewalls provided part of the bed's strength.
You're welcome,
Debbie Downer
Monocoque - Wikipedia
   / Power-trac truck #6
Meanwhile, down at the u-haul assembly plant...
No hint the sidewalls provided any of the deck's strength.
   / Power-trac truck #7
What do you use for loading ramps?
   / Power-trac truck #8
You do the most creative things. Thanks for sharing!
I know that bridge in Durham! Did you know it has its’ own website and webcams? and it still eats trucks despite being lifted...
On an unrelated note, have you seen Hedblom, over on YouTube? The guys to be able to frost a cake with his Engcon tiltrotator.
Back to the cool UHaul PowerTrac limo...
All the best, Peter
   / Power-trac truck
Re:ramps
A lot of aluminum.
Seriously, 10k# rated, 10' long by 15".
Expensive. Worth every penny.
One advantage of the uhaul platform is that it is 8" lower deck height than standard.
I can get on and off w the 6' ramps from my isuzu dovetail....but that's STEEP! And the bolts on the bottom of the 1850 don't clear at that angle. You can see the stowed 10'ramps and in use 6' in the pic.
   / Power-trac truck #10
Anything that leaves the OEM with just a chassis- no way the OEM is going to rely on whatever the upfitter does. I don't know if all trucks are originally sold that way though.
2014 COTTRELL CX-09LS2 AUTO HAULER (A56129)
2014 COTTRELL...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
Kohler 200R0ZD81 Power System 200 Generator (A55787)
Kohler 200R0ZD81...
Ingersoll Rand Air Compressor (A53316)
Ingersoll Rand Air...
2018 Ford F-150 Crew Cab Pickup Truck (A55788)
2018 Ford F-150...
