Power Trac Question
/ Power Trac Question #11
<font color="blue"> But -- slide sideways right against a fence, turn the fronts away and rears hit it.
Same if you drive straight in beside a tree or post and then turn away. </font>
Operator error! /forums/images/graemlins/tongue.gif
/ Power Trac Question #12
<font color="red"> I agree with Fourteen. If you go slow on level ground, the rear wheel follow in the front wheel's tracks exactly. </font>
Unfortunately the fact that you agree does not make it true!
/ Power Trac Question #14
<font color="red"> Unfortunately the fact that you agree does not make it true! </font>
Bob:
It is certainly best that we not ever be known to agree with Fourteen. /forums/images/graemlins/grin.gif
Try a modification of his statement to see if you agree: "In a constant rate turn, the rear wheels follow nearly exactly the tracks of the front. If the wheel is turned, the rear wheels will deviate from the front wheel tracks [and often hit something /forums/images/graemlins/tongue.gif] until a new constant rate turn is established."
/ Power Trac Question #15
<font color="red">Operator error! </font> /forums/images/graemlins/tongue.gif
No way. I slide down hills sideways into fences on purpose. It makes neat mowing stripes -- and tire tracks from the pullout vehicle. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Power Trac Question #16
<font color="red"> It is certainly best that we not ever be known to agree with Fourteen.
Try a modification of his statement to see if you agree: "In a constant rate turn, the rear wheels follow nearly exactly the tracks of the front. If the wheel is turned, the rear wheels will deviate from the front wheel tracks [and often hit something ] until a new constant rate turn is established."
</font>
Sounds about right. Actually Fourteen didn't do a bad job on his second attempt-- <font color="blue"> they do follow very very close, and certainly do not cut the corner and leave significantly smaller radius tracks like the wheels on a conventional tractor </font>
/ Power Trac Question #17
I appreciate Fourteen bringing this to my attention. Sometimes we all get a little to picky.
Take care but not all of it.
Bob Rip
/ Power Trac Question #18
If you reverse your front wheels, the rear wheels will exactly follow the front wheels or at least will never cut a wider circle. And the front will be much more stable when doing loader work.
There used to be a guy on here who extolled the virtues of wheel reversal. But I can’t recall who it was.
/ Power Trac Question #19
<font color="red"> virtues of wheel reversal. But I can’t recall who it was. </font>
LOL /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
I'll give you fourteen guesses
/ Power Trac Question #20
If you reverse the wheels does the right peddle still move the tractor forward ??? ; /forums/images/graemlins/blush.gif /forums/images/graemlins/wink.gif
Giyi-D39 QA Trencher (A60463)
Giyi-D39 QA...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
Giyi Gy-72 QA Mulcher (A60463)
Giyi Gy-72 QA...
2025 AGT Industrial MX-MRW14 (A60463)
2025 AGT...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
