Power Trac PT425
Status
Not open for further replies.
/ Power Trac PT425 #41
That would be great indeed for mowing around trees etc..but what if the grass was a tad damp on a little side slope..traction would be my question.
Thomas..NH /w3tcompact/icons/wink.gif
/ Power Trac PT425 #42
What a nice set up. If you do have traction problems you could always get chains. I bought them and they were not to bad in price, the traction increases dramaticly. I use the small bucket with teeth to move logs, the hydralics are quick enough that with a little practice you can flick the log up and scoop it. The teeth will hold the log in the bucket. I also put an eye in the top of the bucket to hook a chain on. I want to buy the rotary cutter and stump cutter next when finances allow it. Can't wait to here how yours works.
PTRich
/ Power Trac PT425
From left to right is the 60" power angle snowplow in the back, the 10 cubic foot light material bucket in front of that and then the 5 cubic foot bucket with teeth. The 60" finish mower is attached to the unit and the 30" forks are in front of that. To the right is the 48" brush hog.
<font color=green> MossRoad </font color=green>
/ Power Trac PT425
Yeah, it is when I'm at work, however, I uploaded them from home at good old 28.8 zzzzz. I use a freeware program called FTP Commander. I just selected the files that I wanted to upload to my web site and hit OK. Then go fold a load of laundry, have some milk and cookies, watch paint dry... you get the idea /w3tcompact/icons/smile.gif. That's why I listed the file size to the left. Kind of a warning for us regular dial up folks.
/ Power Trac PT425
My lawn is flat, so I'm not worried about regular mowing. However, you are right. When I brush hog my trails there are some slopes, but mostly up and down. On a side slope I imagine that I'll slip to the side. If things get bad, I'll spring for a set of chains as suggested by PTRich. It won't bother the trails to have chains on them a few times a year. The tire tread on the turfs reminds me of the tread on some Armstrong Norseman radials that I had many years ago. It looks like it will do all right in the snow on my paved driveway.
The slippage in the mud wasn't that bad. I just had to go slow. Now, it wasn't real deep mud. And it isn't clay. It is sandy loam. I would be in deep doo doo if it was clay mud with turfs.
/ Power Trac PT425
Where did you get your chains? I'd like to start looking in case I decide to get them.
I have plans for hooks welded to the bucket, but the lights under the canopy come first.
I liked the grapple bucket that they sold, but it was too pricey $$$ and it was on a smaller bucket. I looked at it and am thinking about making my own for the light material bucket to move brush piles. I think it will involve one hydraulic cylinder with hoses and fittings, three bearings, a rod and some 3/8ths steel for the fingers and reinforcing straps. It would be a good project for me over the winter. Right after repairing my IH2500b and selling it.
/ Power Trac PT425 #47
tirechain.com Look under garden tractors to get the right size. I got the 2 link spacing without the v.
They work real good. I like the way the grapple bucket looks too. But it does cost to much, I use rope now.
PTRich
/ Power Trac PT425
Hey, very reasonable price. Thanks!
/ Power Trac PT425 #49
Great job with the video, thanks. How do you like the arm rests? Now that you have time on the machine, would you change anything? size? attachments?
Paul
/ Power Trac PT425
I don't know if the arm rests are worth the extra $100.00, but they are very comfortable, and the seat is nicely padded as well. It was well within the budget, so I got them.
So far, I don't think I would change anything, but would make additional lights under the canopy mandatory.
Some paint was rubbed off during shipping, very minor, and Christmas Eve I received two bottles of paint via UPS from Power Trac at no charge. Good service!
As far as attachments go, I have only used the small bucket with teeth(works great, see videos), the pallet forks(works great, hey, how can you mess up two pointy fingers and no moving parts), and the snow plow. We had about 5 inches of light snow just for Christmas. The plow lifts up and down 52", so making snow piles will be easy. It power angles left and right and that works great. And it tips forward and backward, which allows you to set a gap between the ground and the blade. I let it ride on the asphalt, but raised the gap over the grass and the new limestone that I put in. It has pivoting tires instead of skid shoes. One of the tires was not seated on the rim and therefore I could not inflate it. I looked at the brush hog and it has the same tire, axle, bracket and post as the snowplow. I pulled the pin holding the tire assembly on both and swapped them. Took about 20 seconds. I can now get the tire seated at the local garage. Took video of snow plow in action, but it was horribly back lit, so all you see is this massive shadow coming at you. I'll get a better one the next time it snows. And I'll get videos of the quick attach in operation.
So far I'm very happy. Even my wife said it was kind of neat. She said it took me longer to get it out of the garage than it took to plow the driveway and she is now optimistic that my lawn mowing time will be cut down as well. Positive comments from the spouse about "toy purchases" are very encouraging!/w3tcompact/icons/smile.gif
/ Power Trac PT425 #51
You can re seat that tire yourself. Put a small ratcheting tie down strap or a rope with a small loop on it. Put it around the tire and tighten it until the tire is in rim. If you use rope pull the rope thru the loop and hold it tight with vise grips. Then inflate tires. I have also done this with my hands and had some one else inflate the tire. Make sure the rim is clean. I have seen some people use axle grease to help seat the rim.
Good luck PTRich
/ Power Trac PT425
I'll try that and let you know how it how it works. Thanks!
/ Power Trac PT425 #53
Pretty cool MR! Both the tractor and video that is. Thanks for showing off for us /w3tcompact/icons/smile.gif
/ Power Trac PT425
I keep hoping for snow, but it just melts as soon as it hits the ground. Oh well, at least it is cold enough to start freezing the lakes. I need to go ice fishing soon! Sounds like an excuse to order the power post hole auger for the PT425 and use it to drill my ice holes!
/ Power Trac PT425
There are four new PT425 videos on my web page. They are listed under Snow Plowing, Merry Christmas. The sizes are listed to the left(warning for 28.8 users). All are in windows media format.
The videos include footage of a high speed reverse run down my driveway(8MPH forward or reverse). It just looks strange because I used a wide angle lens set low to the ground.
Also includes good looks at the snow plow, tilt function, lift arms and articulated steering in action.
This machine is a real pleasure to drive. It is smooth and easy to steer. I was a little leary of how it would be to drive an articulated unit over long runs. I thought the steering would be jerky, but it is no different than normal steering. I am getting more comfortable as the days go by.
I bought two more headlights tonight. I will temp them in and then decide where I want them. One will definitely go under the canopy in a corner facing forward. I might put one facing backwards, as there is no light facing the rear. Where to mount it is the question.
/ Power Trac PT425 #56
I love those wheels on the front blade. Great idea. Makes my backwards driving with a rear blade seem really klutzy.
/ Power Trac PT425
Everything out in front works great so far. The wheels are great compared to the steel skid shoes that I had on my pickuptruck plow. They ride over crushed stone well, too.
/ Power Trac PT425 #58
MossRoad, sounds like you'll get your wish for snow tonight. 5-10 inches last time I heard the forecast. Have fun with that Powertrac /w3tcompact/icons/smile.gif
/ Power Trac PT425
Anything, something, just throw me a bone! The snow that is falling right now is melting as it hits the street. Light annoying stuff that just makes the windshield dirty. And it appears to be out of the south west, so it isn't from the lake. I'm getting another load of limestone at lunch today and will spread it right over any snow that is in my parking place. Hopefully it won't freeze into the bed of my truck. I might tarp it until I can unload it tomorrow.
/ Power Trac PT425 #60
Great videos, noticed you have a hitch on the back, did you install this or did it come with unit?
Paul
Status
Deutz D3006 Tractor (A62613)
Deutz D3006...
2007 Grove RT530E-2 4x4 30 Ton Rough Terrain Crane (A61572)
2007 Grove...
2025 8in Channel Tooth Bucket Mini Excavator Attachment (A61572)
2025 8in Channel...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
2019 KOMATSU WA320-8 WHEEL LOADER (A64279)
2019 KOMATSU...
2021 KUBOTA RTV520 UTV (A64280)
2021 KUBOTA RTV520...
