Power Trac PT425
Status
Not open for further replies.
/ Power Trac PT425 #321
Re: Power Trac PT425 Long Day of Fun
I woke up this morning and the weather man said snow in the morning changing to rain with little or no accumalation. I have 6 inches on the ground and it is coming down very hard still. The worst part about it is my tractor is sitting at a friends house where I was doing some work. 1600 feet uphill tomorrow morning should be interesting.
PTRich
/ Power Trac PT425 #322
Just saw and article on rural living, road maintnance. My rake setup has the wheels between me and the rake. If I set them up in front it will be the exact same setup as the "Front Runner". I wonder if this will stop the hoping problem I have now when I push the rake instead of pulling it. I will try it this spring and let you know what happens.
PTRich
/ Power Trac PT425
It would seem like pushing a rake would be difficult, unless its weight was resting on wheels in front of it. Then, as far as the rake is concerned, it is being pulled. Interesting. I'll wait for your findings.
/ Power Trac PT425 #324
You Power Trac fans out there. Like many I am inches away from buying a 20-25hp compact. I mostly mow but need a FEL and a brush cutter. How does your Power Trac do with mowing. I want a 60" (pref. rear discharge). My wife is particular about the finish cut. I want manuverability and comfort mowing 2-2.5 acres some of it hilly. I will be doing alot of mowing under a tree overhangs at the edge of the woods....back and forth hence my attaction to front mounting.
How about the loader. Do you feel limited by the 54" lift height.
Are these machines comfortable for long legs and long times?
Can you get in and out of them easily?
Are they bumpy like a zero turn?
Can you mow quickly?
Have you pulled a loaded trailer?
Last for now does anyone have the brush cutter.
thanks!
/ Power Trac PT425 #325
doggman,
Charlie and MossRoad plus others will answer most of your questions. I am in the process of obtaining a PT425 with many attachments. I did go to SDF to a trade show that PT was attending and drove everything and used most of the attachments. This proved to me this was the machine for me. Be sure to open up the home page for MossRoad.
Paul
/ Power Trac PT425
I have the 60" finish mower, but have not used it yet. I am itching to get the grass growing and test it out. It is rear discharge. You cannot get a bagger for it, so be forewarned( I never bag anyway).
The 54" lift height is an issue if you have to load a pickup truck from the side. It cannot be done without a ramp of some sorts. So be aware of that as well. However, I rarely load a truck from the side. I do load a low trailer and that works fine. I can make dirt piles about 4' high no problem.
I am 6' tall with size 13 shoes and long legs. I have spent several one hour stretches on it with no discomfort at all. The reason that I have not spent longer stretches of time on it are that I get the jobs done so quickly. Really! No kidding! One day I spent a total of 4 hours on it moving lots of dirt and sod, but I was never on it for more than an hour and 10 minutes or so. I jsut kept finding things to do with it and getting them done.
Getting in and out is not too bad. There is a hump that you have to step over. And you will bump your head on the canopy once(twice if your a slow learner like me).
The ride is not too bumpy at all. No bumpier than any other machine that I have operated. The really nice feature is that it twists in the middle, so on uneven ground all 4 wheels stay on the ground. It is very high to get one wheel off of the ground.
My mowing experience is limitted to several hours on the 48" brush hog. I mowed quite a bit of very heavy brush in a very short time. I think it was three passes over a mile of trail. Cut some 1.5 inch saplings with ease.
And I have pulled a rubbermiad cart full of firewood, probably over 500 pounds, with ease. When I get my trailer hitch attachment welded up, I'll tow some heavier items.
You should probably read this entire thread( get several cups of coffee ). Many folks have asked the same questions as you and several owners have contributed LOTS of valuable information about the Power Trac 400 series.
If you have any other questions, feel free to jump in and ask.
/ Power Trac PT425 #327
MossRoad HELP! Our tractors have been verbaly assaulted on the buying a Kubota thread.
PTRich
/ Power Trac PT425 #328
I have the 60" finish mower. I used it two weeks ago to mow some winter weeds and fescue on 2 1/2 acres. It did a nice job. I don't know how it will do on heavy bermuda. There is an old junk pile on the neighboring property where the briars and honeysuckle vines have crept away from the confines of the junkpile. I raised the mower deck up as high as the fel would lift it and then lowered it slowly down over the weeds. Worked really well.
Yesterday I strapped a 25 gallon spray tank to the fork attachment and clamped a 14' spray boom to the front of the forks and then sprayed my 2 1/2 acre lot with Roundup in approximately 30 minutes.
I am 6'5" with size 15's. . I tried the fit of lots of compact tractors before I decided on the PT. The only one that I thought would be more comfortable than the PT was the NH TC series. My tractor does not have the ROP. This probably makes it a little easier to mount and dismount.
/ Power Trac PT425
I'd like to see a picture of that spray setup. Sounds like a great use of the forks several times a year.
And I agree with you about the comfort of the other units. The NH seemed the most comfortable of all. My PT425 is very comfortable as well.
/ Power Trac PT425 #332
Hey gang not to get off the subject but, I think we need our own category we have enough interest in the power trac we need one. What do you think?
KCook
/ Power Trac PT425
While six is technically a group, I'll bet it don't happen for a while yet /w3tcompact/icons/laugh.gif.
/ Power Trac PT425 #334
<font color=red>"While six is technically a group, I'll bet it don't happen for a while yet" </font color=red>
You're telling us quality doesn't count, huh? /w3tcompact/icons/grin.gif
/ Power Trac PT425
Maybe if we start arguing amongst ourselves about red VS. green we will be considered a legitimate group. /w3tcompact/icons/tongue.gif
/ Power Trac PT425 #336
this is the mower you want to use for all the things you mentioned: hills, under trees, nice cut once you learn to keep the beasty steady.
we use a 425 in our cleaning & landscaping business and are very happy with it's overall performance.
to your question about comfort: am 6 foot two, 260 lbs all muscles ...hahahahah size 13 shoes... and operate the machine all day
don't know what zero turns you have that are bumpy.. but pt is not a zero turn. we mowe with our 425 and a special rig 14 feet wide at the time and around 30 acres a day.
if you are lucking for versatility this is the machine!
we have all mowers available for that model. they do well; even in a demanding and competitive area such as the NE USA.
good luck
/ Power Trac PT425
Hey, another Power Trac owner signs up. Welcome. Please tell us more about your machine and any good/bad experiences that you've had with it.
What are you using for mowing that is 14 feet wide? Reel mowers maybe?
/ Power Trac PT425 #338
we own two 57 inches kunz eng. acerease finish mowers, which we pull off to the left of the back of the 425. the only modification is that this year i will only use the 48 inch finish cut pt upfront mower becasue we have too many hills around here. this will give the 425 a cooling brake. so we will be down one foot.
wish they would give us a diesel option in this model.
/ Power Trac PT425 #339
we also use the rough cut mower from Kunz eng., both behind the rough cut mower from pt as well as behind an l series 4 wheel drive kubota tractor with it's own woods rough cut mower.
in an other forum they call me the power trac an acerease addict.
it makes us money and my old back is much happier ... about the only thing i am exploring is to get a similar seat set-up as i have on my Kubota Zero Turn Diesel mower. WHAT A Ride at 9 some miles an hour over some not too nice large properties.
i see you explored that aspect yourself a while back ..any new info??? and what ever happend to the filter situation?
/ Power Trac PT425
Still no luck on the filter search. But I haven't reached 50 hours yet and I have one spare for when that time comes.
How long have you owned the unit?
Status
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
2013 JLG 8042 TELEHANDLER (A67714)
2013 JLG 8042...
2015 Freightliner M2 106 Ambulance (A66736)
2015 Freightliner...
1457 (A65054)
1457 (A65054)
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
