Power to Pole Building 450'
   / Power to Pole Building 450' #21
since you are talking about high amperage to go that far, I would suggest going to diychatroom (DIY Chatroom - DIY Home Improvement Forum) actuall licenced electricians visit that forum and anwer questions like this. i got help with wiring RV outlet and a planer that was a 3 phase conversion to single phase. good luck!
There is no need to go anywhere else. In the 100,000 plus members of this forum, there are as many "actual licensed electricians", engineers, builders, and contractors, as you will find anywhere.
   / Power to Pole Building 450' #22
500 foot of cat6 will work for ethernet, even tho it is way out of spec. expect degraded speeds, could have some problems with some NICS. Fiber would be a better way to go, expecially for lightning protection standpoint, and no problem with a simple SX media converter or SFP module in a simple switch at each end. Fiber does not cost as much as copper any more. Any time you put copper wire of any kind in the ground, you increase your risk for lightning damage. Of course you can protect it, but Fiber is really nice, No Voltage rises.. no Lightning damage! ( You need to protect the AC power to the devices on each end of course, like you would normally do anyway)
James K0UA
That is why I suggested try the cat 5/6 we have a couple of runs at work over 700f at 10mbps duplex and cant see an issue.
If he is gaming that is another whole story:confused2:
   / Power to Pole Building 450' #23
Definatally have the power company engineer come out for an onsite evaluation. It is free and you have nothing to lose.
The $60/month does seem obsurd. I know around here, adding another drop isnt that expensive, and there isnt a $60/month charge. You really need to ask a lot more questions of your power company. They will be able to tell you the appropriate size cable given the length. And around here, we also use the URD direct burial cable. That is how the power companies no it in this area. NO conduit either. But I think they are requier a minimum of 24" deep.
Ask them how they normally install underground. And if you decide to di it yourself, do what they do.:thumbsup:
And I will also vote for 100A service. This gives you the ability to expand in the future. It isnt going to add near the cost to do it now as it would later:thumbsup:
ALSO, check with your power company on the price of whatever size URD they recomend. I have found with my power company, that I can buy 100amp or 200amp URD cheaper than lowes or menards. And I can even get it at cost because my mother works there:D But even the price they charge everyone else is about .30/ft cheaper. Just an example, 100amp URD, which I believe is 2-2-4 AL, is 1.48/ft at menards. It can be bought from the power company @1.18/ft if you are on their lines, and I can get it at cost which is .91/ft. And the difference is similar on their 200amp URD, which I believe is 4/0-4/0-2/0
   / Power to Pole Building 450' #24
For internet, if I use a repeater, I would need to put a power outlet half way there (250 ft) correct? And I need to check on the prices of fiber as I may put an network camera out there..
No the repeater's would be just on the ends and needs power there
John Deere Quick Attach Bale Spear (A50514)
John Deere Quick...
Quick Attach Hydro Slide Pallet Forks (A50514)
Quick Attach Hydro...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
42002 (A51691)
42002 (A51691)
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
John Deere 455G Loader (A48837)
John Deere 455G...
