Power tap for accessorys
/ Power tap for accessorys #1
Jabonee
Platinum Member
Pennsylvania
Mahindra
Greetings. I need to tap in to a fuse box that uses mini fuses for some accessorys I'm adding. I've been told there is a "fuse tap" that plugs into the fuse holder and has a wire pigtail on it. Anyone know of these and where to buy them?:confused:
/ Power tap for accessorys #2
Something like this?
Cooper Bussmann/Fuse and Accessories BP-HHH-RP at AutoZone.com - 1 reviews
Any auto parts place (Advance, AutoZone, PepBoys, O'Rileys, etc.) should have them as well as possibly Radio Shack & Wal-Mart.
Goes by different names - Fuse Tap, Add-a-circuit, Circuit Tap. Probably others too.
These are fine if you are going to add something small, but if you're looking to add more than one thing or the current draw is significant I would suggest adding a separate fuse block.
Something like this is nice (I used one to add a bunch of "goodies" to a motorcycle once)
CARQUEST by BWD Fuse Holder FB70: Advance Auto Parts
Thanks. It was easy when I knew what they were called and where to look. Going to pick some up on my way home. Advanced has them in stock.
/ Power tap for accessorys #4
You are very welcome. Good luck w/ your project.
