Power Sweeper
   / Power Sweeper #1
kcook
Platinum Member
MI
Cub Lawn Tractor
Does anyone have one of these? Can or will it sweep leaves from Grass? Will it sweep or Dethatch old grass from the lawn?
KC
   / Power Sweeper #2
Ken Simolo owns one, so does Alta Vista I think. If you don't hear from them here (they are both really busy) hit them with an personal email.
Oh, and I think Kens is for sale if you are at all interested.
   / Power Sweeper
Thanks, Im just looking at options at this point.
KC
   / Power Sweeper #4
There are several threads here regarding the power sweeper, including one by smartguys describing a problem with storing it. It might be worth you while to search for them, if you already haven't done so.
   / Power Sweeper #5
I have one of these beasts. It is designed primarily for sweeping hard surfaces. I would personally NOT try to use it for sweeping leaves nor for dethatching. I use a tow-behind dethatching rake on my 425, and for the leaves, I use a bagging mower. I used to have a cool little Snapper high-lift mower (GREAT for picking stuff off the lawn, but it died :( )
I think that at a minimum you would need draft control and some offset casters to even attempt using it on soft surfaces like the lawn. As it is, you'd nuke your lawn if you tried.
-Rob
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 66"...
Boat motor turns (A51694)
Boat motor turns...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51248)
UNUSED FUTURE MINI...
