Power Sweeper
/ Power Sweeper #1
kcook
MI
Cub Lawn Tractor
Does anyone have one of these? Can or will it sweep leaves from Grass? Will it sweep or Dethatch old grass from the lawn?
Thanks
KC
/ Power Sweeper #2
Ken Simolo owns one, so does Alta Vista I think. If you don't hear from them here (they are both really busy) hit them with an personal email.
Oh, and I think Kens is for sale if you are at all interested.
/ Power Sweeper
Thanks, Im just looking at options at this point.
KC
/ Power Sweeper #4
There are several threads here regarding the power sweeper, including one by smartguys describing a problem with storing it. It might be worth you while to search for them, if you already haven't done so.
/ Power Sweeper #5
I have one of these beasts. It is designed primarily for sweeping hard surfaces. I would personally NOT try to use it for sweeping leaves nor for dethatching. I use a tow-behind dethatching rake on my 425, and for the leaves, I use a bagging mower. I used to have a cool little Snapper high-lift mower (GREAT for picking stuff off the lawn, but it died :( )
I think that at a minimum you would need draft control and some offset casters to even attempt using it on soft surfaces like the lawn. As it is, you'd nuke your lawn if you tried.
-Rob
Woods DS8.50 (A60462)
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
John Deere 3025E (A53317)
John Deere 3025E...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
Giyi SGB20 QA Stump Bucket (A60463)
Giyi SGB20 QA...
2017 John Deere 8245R (A60462)
2017 John Deere...
