power steering
/ power steering #1
ldp
ohio
1600 diesel ford
Anyone know if adding power steering to a tractor that doesn't have it now is possible for a reasonable amount of money and also reply with parts availablility for a Ford 1600 Diesel.
thank you
Larry
/ power steering #2
Try jackson power steering. They make conversions for some older gas fords.
Soundguy
/ power steering #3
SoundGuy,
What about adding power steering to a NH TC18? Do you think it is possible?
Dave
/ power steering #4
</font><font color="blue" class="small">( Do you think it is possible )</font>
Just about anything is possible. Throw a team of engineers on it.. have a machine shop standing by, and a metal supplier and hyd specialist and supplier on call,.. a couple line techs to bolt it up.. and I imagine you could add power steering to a push lawnmower.. just depends on how fast your wallet is?? /forums/images/graemlins/grin.gif
Not owning a tc18.. I had always guessed that they were already power steering. Seems like the small 4wd one I looked at at the nh deal had been.. but then that was back in 99' so the memory is a bit foggy.
For that matter.. as small as a tc18 is... does it need power steering?
/forums/images/graemlins/wink.gif
Soundguy
/ power steering #5
A quick review of posts here shows that many tc18 have PS.. so perhaps it is an option? for fel use?
Soundguy
/ power steering #6
Yeah it was an option that the original owner did not get. It does get to be alot of work on my arms if doing alot of loader work, and if the front wheels catch something like a rut, I have to let go of the wheel. I think it could break my hand very easily if I caught the wheel the wrong way. It'll spin around very quickly with alot of force.
Dave
/ power steering #7
I had a Ford 1600, see attached pic, that I used primarily as a mowing tractor, so I can appreciate one wanting to add power steering. It was a great little machine and would run all day on a sip of diesel, but man you had to really muscle it in tight corners. If such a conversion is available it sure would be good to know, with used tractor prices going up it might be worth doing.
/ power steering #8
Your this Ford 1600 isn't a Japan tractor with 2-cyl. engine made by Shibaura? I have never seen a power steering kit for them. If available anywhere, it will be very expensive because of numbers of these tractors were not many and no power steering kit Mfg will want to manufacture such kits for few tractors. Your only chance is to find a dealer or two who had sold these tractors late 1970s. They may provide the info.
/ power steering #9
</font><font color="blue" class="small">( Yeah it was an option that the original owner did not get. )</font>
If it was a factory option, than the parts should be available at the dealer. probably not cheap...but how bad do you want it?
/ power steering #10
tc18ny, I would consider looking else ware for the cylinder of you do this... I bent myn on a bever stump on my TC21D and a factory cylinder was $485. My machine being less than a yr old at the time. I bought the factory part, today I doubt I'd do that... if I could find the same part other wares....
/ power steering #11
/ power steering #12
WOW! $485, you coulda' bought a few cylinders for that kinda money. I'm not going to add the power steering anytime soon, it was just an idea. By the time I'm ready to add it, it will probably be time to trade up anyway!
-D
MI-T-M HDS-3005-Z004 PORTABLE PRESSURE WASHER (A65054)
MI-T-M...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
2012 FOR F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FOR F150...
2013 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2013 FORD F150...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
