Power steering
   / Power steering #1
achallie
So now that the tractor is running againI have encountered another problem. It seems as though I have hydraulics for the three point and the bucket, just no power steering. I've found the hydraulic fill point on top of the rear differential, but where is the level check located?
   / Power steering #2
The 1920 has a separate pump for the power steering. The reservoir is located on the engine.
Mike
   / Power steering #3
to nswer the OP's question, the tractor hyd sump level check is accomplished by dipstick in the upper front right side of the op platform.
as said.. the ps has it's own sump under the hood on the right front side of the engine... fill with utf fluid.
soundguy
   / Power steering
Thanks guys. I suppose an owners manual would be a little helpful on this thing. It has been sitting for 5 or 6 years now so I'm trying to go through everything on it before putting it into service.
   / Power steering #5
drain fuel tank.. change filter.. service engine oil and filter.. etc..
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
John Deere 5100M (A50123)
John Deere 5100M...
AUCTION STARTS HERE @ 9AM (A51246)
AUCTION STARTS...
UNUSED FUTURE FT-RT57 57" HYD ROTARY TILLER (A51248)
UNUSED FUTURE...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
HYSTER S50FT STRAIGHT MAST FORKLIFT (A51246)
HYSTER S50FT...
