Power steering
   / Power steering #1
achallie
So now that the tractor is running againI have encountered another problem. It seems as though I have hydraulics for the three point and the bucket, just no power steering. I've found the hydraulic fill point on top of the rear differential, but where is the level check located?
   / Power steering #2
The 1920 has a separate pump for the power steering. The reservoir is located on the engine.
Mike
   / Power steering #3
to nswer the OP's question, the tractor hyd sump level check is accomplished by dipstick in the upper front right side of the op platform.
as said.. the ps has it's own sump under the hood on the right front side of the engine... fill with utf fluid.
soundguy
   / Power steering
Thanks guys. I suppose an owners manual would be a little helpful on this thing. It has been sitting for 5 or 6 years now so I'm trying to go through everything on it before putting it into service.
   / Power steering #5
drain fuel tank.. change filter.. service engine oil and filter.. etc..
Tradewinds Power Unit (A50120)
Tradewinds Power...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
2012 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
2005 Ford E-350 Cargo Van (A51692)
2005 Ford E-350...
2016 Kubota SVL75-2 (A50123)
2016 Kubota...
2016 KENWORTH T680 TANDEM AXLE MID ROOF SLEEPER TRUCK (A53426)
2016 KENWORTH T680...
