Power Steering
   / Power Steering #1
dickr
SOWEST, MONTANA
Kioti lb1914
Kioti Model# LB1914. mfgd 1996. Power steering slow to react to steering wheel turns. When trying to turn the wheels do not react when the steering wheel is turned. Fluid is good.
Have to stop if I want to turn sharp. Appreciate any suggestions. thanx
Dick
   / Power Steering #2
is there a filter in that system?
double check oil level
check for cyl packing bypassing
lastly, check pressure
soundguy
   / Power Steering
Does not show filter in the manual. Looking at the sight glass it's up, in the case seems to be okay. What do you mean cyl. packing bypassing? Pressure? You mean put a pressure gauge at end of the hyd. hose? The workshop manual shows steering motor attach to steering wheel shaft. Mine does not have that. It (steering motor) appears to be at the very end after a universal joint at the front of the tractor. I've heard there was a change but can't find any drawings. Could a bypass valve be the culprit? My hydraulics seem to be fine. (bucket & rear lift.) Appreciate your time.
   / Power Steering #4
I'd get a manual that covered your variation before I proceeded.
is your pow steering on your 3pt pump?
soundguy
   / Power Steering
Yes , it all operates off the one pump for all hyd. right next/behind the trans. A friend more knowledgeable than I said he thought the piece in the front is the directional valve. two hoses in and two hoses going out. I'm looking for another shop manual for it. Thanx
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
set of 4 tractor trailer tires Roadforce (A56438)
set of 4 tractor...
2015 Toro Z Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2015 Toro Z Master...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
3015 (A56857)
3015 (A56857)
