Power steering
/ Power steering #1
Mike in La.
Sulphur,La./Rusk,Texas
6500 4x4 FEL
Have noticed lately that the steering on my 6500 FWD doesn't feel quite right. At times, usually when the fluid is cold, it stops working just for a second then starts again. I'm sure it's in the hydraulic section as everything else is greased often. Anyone else experiencing this? Anyone have any ideas?
/ Power steering #2
Check the fluid level. Could have a small leak somewhere. That happened to me.
/ Power steering #3
After you add fluid, you may have to bleed the system as per the instructions in the owner's manual. It takes a few minutes but is effective.
/ Power steering #4
My 4110 has always done this on occasion, hot or cold. It's definitely not low fluid in my case, and very unlikely it's a restricted filter - mine's been changed at about twice the the recommended intervals and have never had a nasty filter. For the most part it happens when I've got a load of some kind with the loader but it has occurred several times during grass cutting with no load on the front. Doesn't matter if in 2wd or 4wd, happens anytime maybe once or twice in 10-15 hrs. I'd lean towards a sticky valve or spool of some kind in the hydraulics. Don't know if this makes you feel any better but mine has done it for 7 years and 1670 hours but has not gotten any worse or more frequent.
2016 MAGNUM TRAILER MLT6S (A67714)
2016 MAGNUM...
2014 FORD E-SERIES VAN (A67714)
2014 FORD E-SERIES...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2008 Ford F-350 King Ranch 4x4 Crew Cab Pickup Truck (A66736)
2008 Ford F-350...
2014 (INOPERABLE) FREIGHTLINER CASCADIA (A67714)
2014 (INOPERABLE)...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
