Power steering
/ Power steering #1
Mike in La.
Sulphur,La./Rusk,Texas
6500 4x4 FEL
Have noticed lately that the steering on my 6500 FWD doesn't feel quite right. At times, usually when the fluid is cold, it stops working just for a second then starts again. I'm sure it's in the hydraulic section as everything else is greased often. Anyone else experiencing this? Anyone have any ideas?
/ Power steering #2
Check the fluid level. Could have a small leak somewhere. That happened to me.
/ Power steering #3
After you add fluid, you may have to bleed the system as per the instructions in the owner's manual. It takes a few minutes but is effective.
/ Power steering #4
My 4110 has always done this on occasion, hot or cold. It's definitely not low fluid in my case, and very unlikely it's a restricted filter - mine's been changed at about twice the the recommended intervals and have never had a nasty filter. For the most part it happens when I've got a load of some kind with the loader but it has occurred several times during grass cutting with no load on the front. Doesn't matter if in 2wd or 4wd, happens anytime maybe once or twice in 10-15 hrs. I'd lean towards a sticky valve or spool of some kind in the hydraulics. Don't know if this makes you feel any better but mine has done it for 7 years and 1670 hours but has not gotten any worse or more frequent.
2007 Sterling L9500 Tri-Axle Dump Truck (A66736)
2007 Sterling...
Set of 4 Unused 12-16.5N.H.S. ForeRunner Skid Steer Wheels and Tires (A66734)
Set of 4 Unused...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A67714)
2013 POLAR TANK...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
PORTA POTTY (A68842)
2025 Wolverine GB-11-72W 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A66734)
2025 Wolverine...
