Power steering squeeling
/ Power steering squeeling #1
Momboy007
San Diego
Jinma 304
Hello All,
When I was out today using my Jinma 304, I noticed that the power steering was squeeling like a car with a loose belt when I turned left or right. /forums/images/graemlins/confused.gifalso, it turns tighter to the left than to the right. I checked all the fluid levels, they were fine. I also flushed out the entire system when I originally brought it home. Any Ideas?
Thanks in advance,
Rick
/ Power steering squeeling #2
This sound can be caused by the pressure relief valve. did y ou have a heavy load in a front end loader or wheels indeep ruts? or did it only happen at the end of the travel of the steering eacy way?
Hello Chip,
It seems like when the wheels are nearing fully turned. I do have a bucket, but it was empty and I was on flat ground.
I also noticed that some of the hard lines plumbed into the hydraulics are partially kinked?????
Thanks,
Rick
/ Power steering squeeling #4
A serious flow restriction could do it, but would also make steering a bit heavy I think, slight kings shouldn't have much effect. The squeel would be normal at the stops of the travel.
/ Power steering squeeling #5
Just to double check the obvious, you do know that the PS has its own tank in front of the radiator on the 300 series Jinma.
2020 Freightliner M2 106 Johnston VT652 Sweeper Truck (A64556)
2020 Freightliner...
CLUBCART CART (A66091)
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
2016 Komatsu WA320-8 Articulated Wheel Loader (A64553)
2016 Komatsu...
2018 CATERPILLAR 289D SKID STEER (A65053)
2018 CATERPILLAR...
