Power steering conversion on my kubota B8200
   / Power steering conversion on my kubota B8200 #51
There's a subtle difference between 'Powered Steering' (What you did a wonderful job on) and power Assisted steering, which maintains a mechchanical connection between the wheels & the steering wheel. You can 'slow' it down with a larger cylinder to reduce the amount of turning per steering wheel degrees, but don't restrict flow because you might need quick REACTION for loader work.
I would think the power steering rack & pinion from a small car would also be applicable for tractors, either to connect two tieRODS between, or to help the cross-tieROD link used on many tractors and large trucks.
   / Power steering conversion on my kubota B8200 #52
I used a cylinder from a John Deere 318. The cylinder was too short so I bought some honed pipe and extended it to about 8” of stroke. For the end I cut to old manual steering ball joint and welded it to the cylinder rod.
   / Power steering conversion on my kubota B8200 #53
It did not, but they all come with the ports for it, just capped off. These two on top here are for the PS, the two bigger ones on the side are for heavier devices like the FEL. I'm basing this off looking at my father's B7200, which has the same block, has factory power steering, and a factory loader.
attachment.php
attachment.php
Does anyone know what kind of fittings these are that tap into the block in the ps ports ? The Parker store guy had no clue and I sure don’t
I removed the bolt and took it to my guy who makes hydrualic hoses and said i needed that end on one, and the cylinder end on the other, and he did that.
   / Power steering conversion on my kubota B8200 #55
Thanks for all your input on here I used your info for a power steering conversion works great thank you
Glad to hear it's working for you. Really makes a difference over manual steering.
   / Power steering conversion on my kubota B8200 #57
Great write up.
I'm just wondering the weight of your tractor with implements? I have an old Satoh 650g and the steering box is cracked badly. I'm looking at doing what you have done and wondering the limitations of this steering valve?
My tractor is 2100lbs, supposedly 600 for FEL and I have a 600lb box blade, so 3300lbs give or take.
My hydraulic pump only puts out 4.1 Gal/min which is why I figure this steering valve could be a match.
   / Power steering conversion on my kubota B8200 #58
Holding up great. I don't have an hour meter on it but I use it regularly. Power steering is fantastic, no leaks. I'll say it's a bit quick, i think because the kubota has a higher flow rate than the JD318 for power steering. I'm used to it though and I like it. When I get on hte b7200 with factory power steering, it's painfully slow.
That has to do with the ratio between what your steering orbitrol puts out per revolution, and the volumetric capacity of your steering cylinder. So your steering cylinder is a bit small compared to thr JD 318
On fast roadgoing tractors you wouldnt want less than 3 revolutions lock to lock or it gets nervous. Wheel loaders have electrohydraulic joystick steering as an option, but when using the joystick the speed limiter is working.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2019 FREIGHTLINER...
2015 Kubota KX91-3S2 Mini Excavator (A55973)
2015 Kubota...
2008 Jeep Wrangler 4X4 SUV (A56859)
2008 Jeep Wrangler...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A55852)
2014 Utility...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56435)
2020 Westfield MKX...
