Power shuttle has no neutral?
   / Power shuttle has no neutral? #1
Rawbert
Naples, FL
1967 Case 580CK
1967 Case 580CK.
Power shuttle works forward and reverse, but can't seem to find the neutral position.. so the tractor goes either forward when I push the lever to the front or backwards when push it the other way, but no neutral in the middle.. there should be a neutral, right??
A couple of times I was able to find a lever position where the tractor stopped moving, but the lever slowly moves into reverse from the gravity..
How do I fix this?
Is the issue caused by some worn out spool seals/o-rings in the control valve box?
   / Power shuttle has no neutral? #2
All shuttle shifts I've been around have a neutral position between fwd. & rev. I'd suggest to thoroughly inspect the control linkage.
   / Power shuttle has no neutral? #3
I don't know about a 67 C/K, but on my 86 Super E with torque converter drive, the steering column shuttle shift lever is either in fwd or rev. The only neutral is on the 4 spd trans.
   / Power shuttle has no neutral? #4
Yep, no neutral on our 580L.
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox HD-78STD...
2012 Ford F-550 Crew Cab Truck (A55852)
2012 Ford F-550...
2005 John Deere 310G 4x4 Loader Backhoe (A55787)
2005 John Deere...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
