Power Point Plug
/ Power Point Plug #1
powerscol
SW Colorado
CT 235
Has anyone installed a power point plug (12 volt) on their tractor? I want to add one for my baler monitor. Thinking of the deck behind the seat, but need to find a weather proof unit. Otherwise the dash somewhere. I think I have a good place to get power (same tap as the ROPS light bar)
Anyway just checking to see if someone has done this before and how did you do it.
Thanks
/ Power Point Plug #3
There is an extra wire right behind the seat. It comes out just to the right of the top link of the 3 point hitch. You should be able to hook straight up with a couple of connectors,
/ Power Point Plug #4
I ran a two-core wire directly from the battery (clamp-ons) to the back of the seat frame. I mounted a weather-proof 'cigarette lighter' type receptacle/power-point there for use with the amber-beacon "whoop-whoop" mounted on my ROPS.
I suppose that I could splice a fuse in the line, but the beacon draws very little and is only used when I'm infrequently on a public road.
/ Power Point Plug #5
I bought a power point from my tractor dealer that is for a model that comes with them from factory. Used a hole saw (sorry, forget what size but it was a standard size in a set and it was perfect for the power point to snap into.)
Then I just ran some two wire and went right off the back of the starter where the battery cable bolts on and I put a fuse block in there close to where the wire starts.
That's how my dealer had the old work lights powered....off the starter, so I just did the same. I've never had an issue with it.
/ Power Point Plug #6
Do yourself a favor and always put a fuse on the power origination point. That wire going to back is gonna short or get shorted one day and you will bel ucky if it just a wire melt down. Remember, if you don't fuse it, the the Guage of teh wire is the fuse. 10Ga, maybe 15-20Amps before smoking...
Good way to install otherwise. I've done similar (I use ring terminals, a fuse holder, and spiral wrap in the wire) and use the power point as a plug in for my Solar Trickle Charge.
/ Power Point Plug
Thanks folks.
Was out looking today and found 2 spots. One on the dash to the Right of the steering column, and one on the tray behind the seat on the right. Now to find a good weatherproof plug. Many say weather proof, but sure dont took it.
/ Power Point Plug #8
I am probably asking a dumb question, but what do you mean by "power point plug"?
I know it isnt for software.........
/ Power Point Plug #10
Ahh never heard it referred as that.
Thanks!
/ Power Point Plug #12
The dash on my my CK35 had a grommet next to the headlight switch which I removed and installed a marine female cigarette lighter plug with no cutting. Ran wires directly to battery with 20a fuse near battery. I mainly use it for a float charger. Not sure how similar your dash is to mine.
/ Power Point Plug
Interesting - Ill need to look at that. I have my light bar switch right below that location. Thanks
And yes a power point plug is just like a cigarette lighter except is it not rated for the hot end of the lighter. (I.E. don't plug a cigarette lighter into a power point plug) Most of the car ones are metal with no cover (just the lighter). Power point plugs come with a cover. My problem is finding one where the rear terminals are sealable or come with a boot of some type. Right now I am looking at the back fender as it will be closer and out of the way of the hay monitor. The existing wiring back there is already in use, so I will be running a separate fused power wire - probably off the starter hot post like I have done before.
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
UNUSED KIVEL 48" PALLET FORKS (A64280)
UNUSED KIVEL 48"...
PALLET OF (24) 2" X 8" X 27" CHANNEL IRON (A64280)
PALLET OF (24) 2"...
1992 FORD EXPLORER XLT SUV (A64280)
1992 FORD EXPLORER...
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A64279)
2016 CATERPILLAR...
