Power Line to my house was broken
   / Power Line to my house was broken #221
Currently my red clay soil is very moist, so I have a really good ground. By summer, my soil will dry out and it wont be as good. I have a hot wire around my pasture that I had to put in three ground rods, ten feet apart, to get to work in the summer.
Every power pole has a copper wire running down the length of the pole into the ground. I'm not sure how deep they go, but there isn't a grown rod, just the bare wire stapled to the post.
Seems to me that I put in a ground rod when putting the meter base together, but it's not a good memory, so I'm not positive if there is one there or not. I have one ten foot ground rod at both of my panels at my house.
Is there a contact in TX to call and complain about this?
The ground wire generally goes to the bottom of the pole, and has a few wraps around the pole before the pole goes into the hole.
Is your wire still down?
   / Power Line to my house was broken #222
That is NOT correct information.The ground wire is usually #6 copper wire which is stapled to the pole(NOT WRAPPED) fed to driven ground rods a few feet from the pole..
   / Power Line to my house was broken #223
I am talking about it being wrapped down at the base, below grade. It was old practice here, usually called a butt-ground. Some utilities used plates, as well. Driven grounds would be spaced out along the line, or where there may be transformer or other equipment. Depends on the soil conditions.
   / Power Line to my house was broken #224
Worked in Texas doing storm work NEVER seen what you are speaking of.
   / Power Line to my house was broken #225
As far as I know every utility pole that has a transformer on it in this area has a copper wire runing down from the outer casing of the transformer to the base of the pole and then has a coil of the wire stapled to the bottom of the pole.
   / Power Line to my house was broken #226
Not sure where "here" is for you....
But "here" for me in central ohio....this is very common
   / Power Line to my house was broken #227
Friend of mine had phone lines hanging down off a polealong his road. He called and said there’s a crazy guy in the neighborhood who is going to cut it to pieces. He said they fixed it the next day.
   / Power Line to my house was broken #229
Every pole I have ever set we have put a butt ground on it (being #6 copper pulled from the bud to the butt with about a 6' wrap stapled to the butt of the pole , if we are hanging a pot or lightning arrestors, cap bank etc we will also drive rods in addition to the butt ground, this is a very common practice in the South.
   / Power Line to my house was broken #230
it is a common practice here Coobie. Every pole, before it is set has a spiral wrap on the bottom of the pole with the #6 wire. Of course it is stapled all the way down the pole and then the spiral wrap on the bottom of the pole.
2021 Chevrolet Colorado Crew Cab 4WD Pickup Truck (A55852)
2021 Chevrolet...
2023 Kubota BX23s (A53317)
2023 Kubota BX23s...
2014 Cushman Electric Utility Cart (A55851)
2014 Cushman...
2001 FREIGHTLINER MB Chassis (A56858)
2001 FREIGHTLINER...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
Wheel Loader Forks (A53317)
Wheel Loader Forks...
