Power failure
   / Power failure #1
crown
Platinum Member
Winchester, VA
Kubota B-7500
We have lived in our home for 3 years now and from time to time have experienced many power flickers the kind that are a nuisance the clocks blink that kind of thing. Last Nov. my well pump died the power company as well as the insurance company say that the power flickers were not the cause and thus they were not going to pay to replace the pump, sadly I went out in the cold with my neighbor and pulled the pump and installled a new one. Just wanted to get the Board's opinion on what may have caused the pump failure. Won't get my money back but will help my peace of mind.
   / Power failure #2
How old was the pump? Was it a shallow well pump and what brand? Some pumps do just die and I doubt the power going off would do it unless there was a large power surge which would be the only way. Did you have anyone look at the pump to find out what happened to it?
   / Power failure
The pump was only 2+ years old the well is 375 feet deep. My neighbor who is a general contractor says it had the look of one that was struck by lightning. The brand is Sandhandler.
   / Power failure #4
Take it to a repair shop and they should be able to tell you if it was from a power surge then you can go talk to the power company and tell them what you found out and see what they do. A 2 year old pump shouldn't die but all company's do get a couple lemons. Have the shop look at it and go at it from there.
Good luck.
   / Power failure #5
Usually pumps can handle a good amount of surge. Most of the time the starter capacitor will die. At my old house, the power was terrible. The refigerator compressor was the first to die from all the power flickers.
As for lightning, I have experienced that too. I took a lightning hit... Three days later I had silt in my water. The fifth day the motor stopped. I replaced the starter capacitor and the pump started working again. Two days after that I had enough sand in my water that I could have started making beachfront property.
I call the well driller, he tells me lightning hit my well, blew a hole in the casing about 40 feet down. I called my insurance company, and they wanted me to prove the lightning damage by having the well driller back out my well casing. The well driller states the probability of getting the pipe out intact is very slim. I then was gambling that if I can prove the damage I get it paid for. If the pipe breaks, now I have to pay for the pipe being pulled out, and a new well. The insurance company won, I did not want to gamble and take the risk of paying an additional 2,000+ dollars for pulling the old pipe out.
The insurance companies know how to get out of paying!!
Joe
   / Power failure #6
A few years ago our pump was hit by lightning. There were severe storms in the area, but nothing that I thought was particularly close. Didn't know the pump was out until the middle of my shower the next morning! /w3tcompact/icons/shocked.gif My insurance company, State Farm, said to call a local well drilling outfit and get a new pump installed. They came out the same day, pulled the pump (200' down) and could tell by the wires that it had been hit. State Farm was great.
   / Power failure #7
What is the voltage on your pump..120V or 208&203V.
If your pump a 208&230 volts and your power company not giving you enough volts than in period of time you pump shall burn out...its know as brown out or dirty power.
There a couple of choices you can do,have a bigger transformer install,or install 200-208 single phase volt pump.
If you live in area which other are useing equipment like welders etc..that would indeed raise heck w/your voltage to your home..the closer to the electric sud station cleaner the power,and of coarse what I just wrote no power company would admit this could be true,for it would cost them $$$$. /w3tcompact/icons/wink.gif
   / Power failure #8
Crown, do you have sprinklers? Around here a lot of pumps go from cycling on and off to much when the lawn sprinklers are running. They are supposed to be adjusted (flow) to keep the pump running continuously. Our neighbor lost a pump after only one year due to this. Good luck /w3tcompact/icons/smile.gif
   / Power failure #9
While it won't help with drops in power, a panel mount or whole-house surge surpressor would help in lightning situations. You can check them out at your local electrical supply outfit or even Lowes of Home Depot. They basically work by clamping the voltage at a set limit and helping to eliminate spikes and transients from motor starts, lightening, line switching and the like. I have seen them run from about $50.00 on up. In general, the heavier duty ones are worth every penny.
   / Power failure #10
the only promise that power companies make is that the frequency will be 60 hertz, the voltage will swing around the set voltage. As for the power surges or spikes, these can be caused by neighbors wielding, large motors turning on such as grain blower motors. Remember you are out in the country, in town a lot of these things are controlled through zoning. This is just the fun of country living.
Dan l
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A53473)
2012 NEW HOLLAND...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
4X8 PUMP (A53843)
4X8 PUMP (A53843)
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
