Power fade???
/ Power fade??? #1
Brushhill dave
central alberta
kubota 2360,Ford 4610,111jd,gt200 husky
So about 2x per hour of use I suffer power fade on my bx2360.... Has anybody else expirence s this problem?? The tractor has about 15 hours on it.
/ Power fade??? #2
What are you doing when it happens?
15 hrs, but what year is the tractor?
/ Power fade??? #4
Hard to say, but if it's an early 2012 with only 15 hours of use, your diesel could have grown algae in the tank which is causing the fuel filters to clog. If that fuel has been sitting a long time, it could be contaminated. Have you talked to your dealer's service dept about the issue? What exactly are you doing when it happens?
/ Power fade??? #5
WHat are you doing when it looses power? On any slopes?
Like chris.. right now, im suspecting something in the fuel system.
/ Power fade??? #6
Changing the fuel filter could be a starting point. Is the RPM dropping or not when you sense the 'fade'.
/ Power fade???
I have already spoken to the dealer and have purchased a filter. Not really what I was expecting the kubota to have for a filter. I had expected a screw on hard case instead it's just an inline has jobby looking deal
/ Power fade??? #8
Unless they changed it on the newer models, there are actually two fuel filters, the one you can see, and another one underneath, nearer the fuel tank. The one underneath catches debris from the tank first and is most likely to clog. Sorry my knowledge is dated since my equipment is older, but check with the dealer to be sure.
This shouldn't happen at 15 hours. Dirty fuel is the obvious first thing to check... hope that's all and not a problem with the tractor itself.
/ Power fade??? #9
SHould still be 2 filters on a BX.
If it turnes out to be a filter problem, have a look at my BX filtration thread in my sig. Since you mentioned that a BX should have a "proper" filter, I agree with that statement and added one to mine.
/ Power fade??? #10
I'd have the dealer look at it, then if something is wrong later you're on record with the problem. My dealer comes to the house with a service vehicle for repairs, you might ask if they can do that for you so you don't have to move it.
Landhonor Plasma Cutter (A66408)
Landhonor Plasma...
Cattle Feeder (A65640)
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
2003 Dodge Ram 3500 Pickup Pickup Truck, VIN # 3D7MU48W53G758623 (A65563)
2003 Dodge Ram...
Frontier RC2060 5ft Rotary Cutter (A65640)
Frontier RC2060...
2007 Chevrolet Silverado 3500 4x4 Service Truck (A64556)
2007 Chevrolet...
