Potential power increase for CK2610?
   / Potential power increase for CK2610? #12
There are a few who have. I can confirm that is the fueling screw under the cap. It will make more power. It is the same engine as the old 35hp model, and still makes that on non us models
   / Potential power increase for CK2610? #13
What’s the process, loosen the bolt and turn the screw in?
   / Potential power increase for CK2610? #14
Following.....
   / Potential power increase for CK2610? #15
What痴 the process, loosen the bolt and turn the screw in?
You would unscrew about 1/2 turn and see how that works. It is better to have it on a dyno and just adjust till you see a little smoke under a load. Without a dyno, small adjustments is best. Maybe 1/4 turns till you are happy. Just don't go to far.
Remember if you have a warranty, removing the cap will void warranty.
   / Potential power increase for CK2610? #16
OUT... in 1/2 turn increments and snug the nut back up..
NOW, rev the engine.. once u get smoke STOP..
IF its to much smoke, u KNOW u went 1/2 turn.. so screw it IN 1/4 turn..{1/2 of a 1/2}
To get more SPEED/RPM, BACK OUT on the hi speed stop screw..
SAME METHOD, go in 1/2 turns{out}.. so u KNOW what to do if its to much..
Doing this will probably shorten the life of your engines, so be careful & dont cry when it blows up.. YOU DID IT..
   / Potential power increase for CK2610? #19
Would the CK 30 be a similar adjustment?
Probably, but do your research and listen to what thepumpguysc said in post #16!
2015 CASE CX300C EXCAVATOR (A52707)
2015 CASE CX300C...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
2023 Club Car Carryall 700 Utility Cart (A55851)
2023 Club Car...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2022 John Deere R4023 Self-Propelled Sprayer (A53485)
2022 John Deere...
