Potato Cannon
   / Potato Cannon #1
truckdiagnostics
Platinum Member
Central WI
7753 bobcat
Works really well! swear it will go a mile. When you pump 130 psi into it is kinda scary as you can feel the PVC expand.:cool2:
   / Potato Cannon #2
I made one with a coaxial barrel and tank. It used a "quick exhaust" valve to fire. Could launch things out of sight. Used 2" PVC for the barrel.
Then I made one that could be breach loaded, out of copper pipe with a 1" barrel.
You can feel the copper get warm as you charge it.
   / Potato Cannon #3
PVC explodes into lethally sharp shrapnel.... Just so you know. Btdt.
   / Potato Cannon #5
Somebody shoot a flaming tennis ball over here in Ea WA and there will be homeowners looking for them. This time of year its so dry the grasshoppers rubbing their hind legs together can start a wildfire.
I saw a video clip of a PVC/hairspray potato cannon explode - the guy got shrapnel in his arms & chest.
   / Potato Cannon #6
The hairspray and ignition is probably far more dangerous than compressed air well below the pipe rating. But, still, PVC isn't recommended for air lines, either, though many use it with no problem.
Bruce
   / Potato Cannon
The PVC is rated for 250 psi, don't remember what fittings are actually, I did however make sure everything was with in specs including the glue/cement! Gluing it up can be tricky and it takes two people, it is designed so that the air rushes into the center.
   / Potato Cannon #8
Can't powder coat that. Bummer!:laughing:
   / Potato Cannon #9
PVC is rated at 0 psi of compressed air.
tcartwri is correct. It may not fail, but it defiantly can.
I was once injured by a PVC compressed air line that failed.
I would suggest you keep onlookers clear of it.
   / Potato Cannon #10
Your design puts a lot of lateral loading on that discharge pipe with every "firing" and will eventually cause it to break at or around the union. PVC is very brittle and gets worse with age and cold so I would be very cautious about using that thing. There is a reason most potato cannons are in-line with everything. Each bend also gets hammered with air hammer effect when discharging. DO yourself a favor and destroy that thing before you get maimed or killed by it.
   / Potato Cannon #12
Good points.
At the very least, wrap it with filament tape.
   / Potato Cannon #13
I like potatoes too much to waste them.
I did built a bowling ball cannon though.
   / Potato Cannon #14
A great quick action valve is a 1 inch irrigation valve , you can operate it on a 9 volt battery .
   / Potato Cannon #15
If the valve is big enough. You need a valve that is bigger than the barrel size, or you could have a serious restriction.
When you get up to 2" barrel size, valves gets expensive.
I made my own, and it worked great, but a 4" PVC pipe at 100psi (air) is unnerving. I played with it for a while, then took it apart.
Glad I did it, won't do it again (with PVC).
   / Potato Cannon
You would get a tighter fitting potato (thus longer distance) if you beveled the inside of the pipe rather than the outside of the pipe.
The outside edge is beveled so that you can cut the potato when you jam it in. Tight fit has not been the issue. You have to close the valve when you load it other wise peelings get into the valve. You end up with such a tight fit you can't push it in.
I have a shipping blanket with a hole in it that I have been covering it when using. Yes, pvc shatters when it breaks, I do believe I will wrap it in duck tape and use the shipping blanket.
   / Potato Cannon #19
If you put most of the bevel on the outside, and just a little bevel on the inside, you can trim the excess potato, and get a tight fit. A tight fit isn't so necessary with a pneumatic cannon, as with combustion cannon.
And see if you can find the kind of tape that has the little fiberglass strands in it. Much stronger than duck (duct) tape.
   / Potato Cannon #20
A long time ago back over 40 years ago the guys at work told me about a potato gun they made at work. They made it out of three inch 6061-T6 schedule 40 aluminum pipe and had the welder tig weld up one end. They used a water soaked roll of paper towel or toilet paper (not sure which) for a projectile and a spray bomb of ether (the real stuff) starting fluid for propellant. For some reason they tested it inside the building which in retrospect wasn't the best decision...go figure, eh. :D They shot that wad of soaked paper across the shop and it cracked a Cindercrete block in the wall (I did see the block) and actually shook the building enough to get the people in the office part of it out to see WTF was going on.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
17501-FL (A56857)
17501-FL (A56857)
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
