Posthole Digger Posthole Conundrum
   / Posthole Conundrum #31
The best corner posts that I have found are railroad ties. A little harder to put in the ground, but I have never had one come out.
   / Posthole Conundrum #32
One thing I've learned is that the upper end of the diagonal brace needs to be above the top wire. If it isn't, the wire will try to pivot the post around the brace and the end comes out of the ground if you have enough tension on the wire.
Sean
   / Posthole Conundrum #33
After doing some research on fence corners, I stand corrected. The horizontal top rail plus the wire X is an acceptable corner for a wire fence.
   / Posthole Conundrum #34
If this is for a corral then forget about it. Dig it as deep as you can and plant the posts. You were not really thinking about using a shopvac were you?
Holy mother....I guess I should have read all the posts. I have now seen everything!
   / Posthole Conundrum #35
Up here Ontario hydro is starting to set their poles in holes that have plastic culverts in them. They then pack the area between the pole and culvert with sand. When the pole needs replacing they bring in a vac truck to suck out the sand and plunk in a new pole without having to drill a new hole. In rock they bore a hole and forget about the plastic...
I have never seen a wire fence without the diagonal brace in the corners.
   / Posthole Conundrum #36
What would the additional brace accomplish?
This brace resists the tension in the wire which causes a torque on the post causing the post to lean in the direction of the wire.
If you look at the pictures you will see that the corner posts were "braced" with an X between them and the next post in line in an attempt to strengthen them. Unfortunately theses wires are only strong in tension, and provide no compressive resistance. You need a wooden brace from the top of the corner post to the base of the second post in both fence directions in order to keep the corners upright.
This article illustrates two methods of bracing properly bracing a corner post How to build a good fence for your homestead by Charles Sanders Issue #103
Exactly the way I did our horse pasture 7 years ago. They had a free catalogue at TSC about tensile fencing that described this exact process. They all still look perfect. Corners and braces 48" with redi-mix. Line posts at 36" with no cement.
   / Posthole Conundrum #37
Looking at the pictures of what you're replacing, that corner looks to be wider than 90 degrees. That can be a little harder to brace and not have it lean into the corner. You may have better luck using a double corner post (one for each side with non-tensioned wire between). Or adding an additional brace splitting the angle of the corner.
-rus-
   / Posthole Conundrum #38
I bought a newer style post hole digger at Home Depot. It might be a ridgid brand, since it's orange. But it uses a different design which has 2 hinge points and the handles only spread hald the distance to open the shovels. Works great for deep holes.
   / Posthole Conundrum #39
I agree - there's nothing wrong with the brace design. It doesn't look like the posts were well tamped. The corner post came up and it would do the same thing with a diagonal brace under compression.
I agree. Looks like the original builder tried to rely on a sack of sackcrete to hold it in the ground.
Here is another good site on fence building:
http://www.staytuff.com/build/
Thanks.
I will check it out.
E/S
GROUND PROTECTION PAD 8X4 15 COUNT (A55745)
GROUND PROTECTION...
1998 POLAR TANK CRUDE TRAILER (A55745)
1998 POLAR TANK...
2005 Ford Taurus SE Sedan (A55853)
2005 Ford Taurus...
Utility Trailer (A52377)
Utility Trailer...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
