Posthole Digger Posthole Conundrum
   / Posthole Conundrum #1
E/S
Reno, NV
Kubota M8540HDC12-1 4x4 w/ Cab
Dug a whole bunch of really nice 9" x 4' holes for the llama corral today.
Problem is they have to be a full 4' deep and a regular hand porthole digger will not close enough to hold the dry loose dirt.
The wife is threatening to getting my shop vac and have me string 500' of extension cord.
Any ideas on how to save my shop vac and get me out of just saying "Yes Dear " for the next few days ?
   / Posthole Conundrum #2
Make a "dipper" with a large rounded cup on the end attached to a five foot handle. Would that work? Or maybe build it more like the long handled sand scoops (without the perforataed holes for sand to sift through) that metal detectorists use at the beach?? Yeah, it would still take a while to clean out all those holes but unless someone has a better idea????
   / Posthole Conundrum #3
pour some water in the holes to make sticky mud and/or get an auger type digger
   / Posthole Conundrum #4
Actually, using the shop vac would work very good as long as all that is at the bottom of the hole is powder. It will take much longer if you have stones much over an inch. Other than dragging out that much cord, the vac would be the easiest way to go in my opinion. I have used ours many times to clean around concrete (rough edges and all) before pouring new concrete against the old.
   / Posthole Conundrum #5
What gauge cord? You could burn up the vac motor with lighter gauge.
Steve
   / Posthole Conundrum #6
Steve
10 gauge most likely. If it were me, I would use my generator though, I don't have but 400' of 10 gauge, or are they 8 gauge, now I'm not sure. :eek:
   / Posthole Conundrum #7
Dig 'em 5' deep. The key to emptying a hole of the dirt is to stop the auger while its fully in the hole and carefully lifting it out. Add some water if the soli is very fine or sandy.
   / Posthole Conundrum #8
You just have to make them bigger around at the top so you can open the handles
Thanks for all the replies, I think I will dig out the generator and try the shop vac.
If it works, the wife was right and I win !
If it doesn't work, I tried her way and I still win ( I hope ).
E/S
   / Posthole Conundrum #10
I still have one of those folding shovels, that used to be called an "entrenching tool" by the army.
When I had to dig some 5' holes, I took the wooden handle off and substituted a longer one. The shovel blade can be locked in a position 90 degrees to the handle, and this will scoop your dirt out.
I think a generator and shop vac is a better way to go.
CATERPILLAR 320GC EXCAVATOR (A51242)
CATERPILLAR 320GC...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
2018 FORD F-150 (A52472)
2018 FORD F-150...
IH 445 Square Baler (A50515)
IH 445 Square...
UNUSED JCT QUICK ATTACH 72" HYD 4N1 COMBO BUCKET (A51244)
UNUSED JCT QUICK...
