post pics of your fuel storage solutions
   / post pics of your fuel storage solutions #1
workinallthetime
Tulsa, ok
L45 TLB, ZD326P
i have recently moved up in tractor size and the amount of fuel used is very noiticable, i have always used clean plastic 5 gallon cans and tossed them out after a couple years or if they get contaminated. i am thinking i can purchase a 55 gal drum off offraod locally but not sure. if i am able to purchase a drum i will have to figure out how to x-fer the fuel and how to store it w/o it getting contaminated. i am in oklahoma where the humidity is very high so that is a big concern. i know about alge as i spent many years as a diesel tech.
the L45 should be able to pick up a drum full of fuel if i place it on a pallet to transport it and i have a barn that stays pretty cool inside during the summer.
i do not really want to purchase a tank, i remember too many trucks that got filled by their "farm tank" and contaminated the entire system.:thumbdown:
thoughts, pic's, suggestions many thanks.
   / post pics of your fuel storage solutions #2
Initially I went to this:
It worked well but was a bit worrisome unloading it from the truck with either the bucket, or with forks and a pallet.
When I went to bigger equipment that had 25+ gallon tanks, I moved up to this and have the fuel delivered:
As you can see, I have a Goldenrod water and particulate filter on it but I have never had to replace it and I have not had any algae problems. I think if you keep the water out, that's a big start in avoiding algae. IMO, the plastic tanks are better at avoiding moisture than metal tanks. I keep mine inside btw.
It's a lot less hassle having the fuel delivered although the bill hurts a lot!
   / post pics of your fuel storage solutions #3
I use a 30 gal drum with same style pump as well. Use the Goldenrod water filter and keep it under a shed.
Lift it with the bucket and strap with hooks on each end in the water drain holes I drilled in the lip of the barrel top.
Works great for me. Advise to use a water/particulate filter in line. Only adds $20 to setup.
   / post pics of your fuel storage solutions #4
Been Using above for a number of years now . Maybe a bottle of conditioner / stabilizer on a yearly basis , ( Seriously , If I remember , I put something in , if not , Oh Well ) . Last purchase was 4 or 5 years ago and added 100 gallons to the 50 or so that was still in it . Never had a issue in tank or tractor with any growth , water , or other problems .
Fred H.
   / post pics of your fuel storage solutions #5
I've been using this for the last 20 years. 500 gallon double walled for secondary containment. Used a 500 gallon mounted on a stand with gravity feed for the 20+ years previous.
Terry
   / post pics of your fuel storage solutions #6
I originally started by using 5 gallon containers to fuel the tractor. Then for many years I used a 15 gallon (it actually holds 17) plastic container. I filled it from the 5 gallon jugs bought at the local truck stop and used a 12V electric fuel pump run off a trailer brake battery to fill the tractor. Just recently I changed to a 275 gallon tank (bought used for $75.) with a 12V pump I bought from Northern tool (Pump with hose and nozzle was $150.) I added a spin on filter bought from NAPA. I wired up a quick connect 12V plug on the tractor to power the pump. I had the fuel company put in 100 gallons when they delivered my home heating oil which is #2 ULSD diesel. I use Power Service additive in both tanks for any moisture and anti gel agent.
   / post pics of your fuel storage solutions #7
I built a stand from some galv. pipe I had laying around and got this 100 gallon tank from someone who moved put gas in their home and had no use for this fuel tank. I cleaned it up inside and outside and of course painted it JD Yellow. It is standing next to a shed now because we moved, but it is gravity flow.
I take it down with my tractor forks, take it to the station with a trailer or my truck and fill it, hoist it back up and off we go.
I had to put the filter near the end of the hose or it didn't work properly.
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55218)
2024 BCL...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A53422)
2014 Chevrolet...
