Post Hole
   / Post Hole #1
southwind26
ash fork, az
1971 John Deere 60hp model #401AJ, serial # 190601T with a #7310 loader with 1 yard bucket. Engine type 4202DT 4 cylinder diesel, serial #279020T with detachable backhoe model # 9250 has a 24 bucket with good teeth. John Deere considered this mode
Hey Everyone
I need a little help, the shear pin on my Post Hole auger did its job and sheared but now the drive shaft is stuck on the shaft of the auger head and I can't remove it to replace the shear pin. I've tried to use chisels and wedges but with no luck SV400002.JPG anyone have any ideas?
   / Post Hole
Thxs deerseeker001
   / Post Hole #4
Beat , bang , cuss and fuss , then buy a new one.
Actually I would try lining the hole up with the piece that is still stuck inside and drive it out with a punch.
   / Post Hole #5
Scratch that. There is probably a clip ring on the inner shaft holding it in place. ( got to typing before I looked at picture.
   / Post Hole #6
My neighbor had the same problem with what looks like the same PHD. We soaked it in WD40, and used a breaker bar and small sledge. It was a real PIA, but finally came off. It had been on so long, it was rusted badly. Looks like you got the same problem.
   / Post Hole #7
Heat the yoke with a torch and while hot spray wd40 between the yoke and shaft . And it will pull right off by hand .
Sent from my iPhone 5 using TractorByNet
   / Post Hole #8
2 pipe wrenches, 1 to hold auger from turning the other to rotate PTO shaft. Line up the shear pin holes and drive old bolt out with a punch. Reason it stuck is bolt started bending before breaking, use next stronger grade of bolt. This will allow it to shear cleaner and made replacement easier.
   / Post Hole
Thxs everybody. So far I have tried some propane heat but that didn't seem to get hot enough. I tried to move the shaft with pipe wrenches and a cheater bar, I had a grade 5 bolt for a shear pin, I tried a grade 8 but that torn the shaft in half. Tomorrow I will put the torch on it and see if that will heat it up enough to move.
   / Post Hole #10
Spray wd40 in it while hot it's red hot . Trust me it works .
I was trying to get a stuck pto shaft unstuck beat the crap and everything I thought I could do . Tell someone came by while I was trying to get it to move . And they said heat it hot and spray wd40 in between the two . I didn't believe them so I didn't try it tell after they left . And guess what it worked like butter .
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2013 Volkswagen Passat Sedan (A51694)
2013 Volkswagen...
2025 AGT 750 (A50123)
47 ft. Portable Transfer Dock (A53117)
47 ft. Portable...
2015 Ford Focus (A51694)
2015 Ford Focus...
Coleman 274BH Lantern Edition Travel Trailer (A51694)
Coleman 274BH...
