Post Hole Driver Return on a M7040
   / Post Hole Driver Return on a M7040 #11
The filler tube adaptor for the Driver looks nice. If you want to remove it raise the lower links and use a pipe wrench to remove and place the original plug on the filler hole. I have used all 3 of the holes in the upper link before and can't tell a difference between the upper versus lower. Just my $.02.
   / Post Hole Driver Return on a M7040 #12
Why not add a 45 degree elbow fitting into the filler hole first, then use it to offset the whole pipe over ? This would give you finger clearance wide for installing pins in middle,lower toplink holes. Its not the ideal solution , but perhaps its better it is now. Its either that or put in a shorter pipe. I am not sure why was a long one wass installed in the first place.:confused:
Thanks for all the comments: a pipe wrench in the toolbox may be in my future, but we are first going to try shortening it so that a wrench handle will just clear the pto safety cover. I'll post a final picture when done.
   / Post Hole Driver Return on a M7040 #14
What comes to my mind is it could be easier to hold a funnel for adding hydraulic fluid or the bouncing of the Driver when it slams the post could jar the return line out and cause hydraulic fluid to spray over the operator and tractor. Maybe the previous owner clamped it down or used a bungee cord to hold it in the filler tube.
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A51039)
2010 Gleaner 9250...
