Posthole Digger Post Hole Digger Stand
/ Post Hole Digger Stand #21
That landpride stand is the best setup I have seen for a posthole digger stand. It looks to be very well engineered. Clever design.
/ Post Hole Digger Stand #23
Jim,
Isn't that a display stand /forums/images/graemlins/crazy.gif
I don't think it will make attaching any easier but it will hold the unit for storage.
Later days,
Michael
/ Post Hole Digger Stand #24
jwjimbo . . . the problem with that stand is that you can't just back up and hook it up. The toplink connector is on the ground and needs to be a couple feet off the ground to match up with the tractor. I keep my PHD on the ground and wrestle it into place, I have found that if I connect the bottom pins first, I can rotate the top into position. It is easier now that I installed a Pat's Easy Change, but I think the best solution might be to hang the PHD from a stand that is on wheels. There is a link to black pipe stand that someone made, it seems to be the ideal way to store it so that it can be hooked up with ease.
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
EZ Trail 672 Head Cart (A66285)
EZ Trail 672 Head...
