Posthole Digger Post Hole Digger Stand
   / Post Hole Digger Stand #1
zuiko
Platinum Member
Minnesota
JD 990 4WD
It seems to me I saw a thread a while back that had some pictures of people's wooden PHD stands. I have been only been able to find pictures of steel versions. I don't have any welding gear so I'll have to make mine out of lumber.
Anyone know the thread I'm talking about or have pics of theirs? Thanks!
   / Post Hole Digger Stand #2
I don't have a pic, but I did see one last weekend. It was a sales display stand, and to me it would require some rework to make it function well to attach/detach the auger.
It was metal, but should be able to be constructed out of wood as well.
If you can imagine a diamond shaped structure laying on the ground. At one end, the auger tip sits in a bracket.
For the sides of the diamond, there were vertical supports that the lower 3 pt attach points went into.
I looked at it awhile to see if I wanted one for my PHD, but figured I'd still need a tree limb or hoist deal to attach it to the tractor.
The wife's not happy, but my PHD hangs in the back yard from a rachet strap.
Hope this helps.
Ron
   / Post Hole Digger Stand #3
Here's mine that I made with blackpipe:
Stand for Post Hole Digger Made from Pipe
It has held up well, no sign of wracking or loosening, and I've had the digger off/on about 10 times, rolls easliy around the garage.
   / Post Hole Digger Stand #4
Have any trees?
When I first got my PHD I used a tree and it worked pretty well. I just tied it up with a rope. I have attached a picture...
Now that I have a shed, I hang it from a chain. That is even better, because I can take it off the tractor then rotate it around against the wall.
Guess if I did not have a tree or shed though...a stand would be what I would be using too... /forums/images/graemlins/smile.gif
I do remember a thread on PHD stands sometime in the last 6 months or so. You might find it with a search...
   / Post Hole Digger Stand #5
The PHD is, for me, the most difficult implement to put on and take off, and to "store". So I have thought about sinking a 55 gallon barrel, filling it with coarse sand, lightly oiling the sand with machine oil, and then when I want to take it off, I will back up to the "pit" and auger in and then unhook it. It seems to me that that would be a very convenient way to not only have it stable when you unhook it and hook it up, it would also conveniently store it. I suppose there are a number of flaws with this idea, but unless I am persuaded this is not doable, I may give it a try. the barrel rim would be about 3" above ground level, and the surrounding ground would slope away, and I would tarp it. Thoughts ?
   / Post Hole Digger Stand #6
<font color="blue"> The PHD is, for me, the most difficult implement to put on and take off, and to "store". </font>
Gee, I just mentioned this in another thread, but I have exactly the opposite experience!
For me, the PHD is the easiest of all implements to deal with.
Now I must say that I have always from day one hung the thing from something. At first it was a tree, and now it is from a floor joist of the loft in my shed.
I honestly don't think there is another implement that is easier to hook up in my case....maybe a boom pole...haven't used that in a while...
I think the key is having the PHD hanging from something...works for me anyway... /forums/images/graemlins/smile.gif
   / Post Hole Digger Stand #7
Bill, you have identified why I have more difficulty - I didn't have it hanging from anything. The other implements were stationary and I could just back up and they seemed so much more manageable. Then, once I left the PHD in a hole and came back to re-hook it, it was so much easier - thus the idea about sinking a barrel and filling it with sand. I don't have - or can't think of a place I can hang the PHD from - but will consider that option as well. I really had a bear of a problem the first time I hooked it up - not knowing at all how to begin to do so - and I hooked up the bottom links first - that is not the way to begin in my experience. If I leave it in a hole and hook up the top link first it is relatively easy.
   / Post Hole Digger Stand #9
Not clever enuf to make a stand (or too lazy). Here's how I store my PHD.
   / Post Hole Digger Stand #10
Here'd the PHD ready to be installed on the tractor.
2004 JOHN DEERE 5320 TRACTOR (A51243)
2004 JOHN DEERE...
Case IH 3408 8 Row Corn Head (A52349)
Case IH 3408 8 Row...
2010 DODGE RAM 2500 FLATBED TRUCK (A51243)
2010 DODGE RAM...
New Holland 273 Hayliner Square Baler (A50515)
New Holland 273...
10' Feed Bunk (A50515)
2008 JLG 600S TELESCOPIC MANLIFT (A51242)
2008 JLG 600S...
