Posthole Digger Post Hole Digger Stand
   / Post Hole Digger Stand #21
That landpride stand is the best setup I have seen for a posthole digger stand. It looks to be very well engineered. Clever design.
   / Post Hole Digger Stand #23
Jim,
Isn't that a display stand /forums/images/graemlins/crazy.gif
I don't think it will make attaching any easier but it will hold the unit for storage.
Later days,
Michael
   / Post Hole Digger Stand #24
jwjimbo . . . the problem with that stand is that you can't just back up and hook it up. The toplink connector is on the ground and needs to be a couple feet off the ground to match up with the tractor. I keep my PHD on the ground and wrestle it into place, I have found that if I connect the bottom pins first, I can rotate the top into position. It is easier now that I installed a Pat's Easy Change, but I think the best solution might be to hang the PHD from a stand that is on wheels. There is a link to black pipe stand that someone made, it seems to be the ideal way to store it so that it can be hooked up with ease.
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
1980 ATHEY AB6905 MOTOR GRADER (A52707)
1980 ATHEY AB6905...
2020 LOAD KING JBTR-56 (A55745)
2020 LOAD KING...
2013 PETERBILT 367 (A55745)
2013 PETERBILT 367...
