Post Hole Digger Seals
/ Post Hole Digger Seals #1
paul dyar
Anderson S.C.
TC33DA
I am having trouble finding seals for a post hole digger. The make is unknown. The input shaft is 1.25 the od of the seal is 1.75 The output shaft is 2.0 the od of the seal is 2.6250. I have called 2 places and been on Timken site. So far no luck. The number on the cap is 901212250222.
Thanks for any help,
Paul
/ Post Hole Digger Seals #2
Grease.
/ Post Hole Digger Seals #3
I bought an odd size seal from these people once, but I had a number I could read off the old seal. If you could find a chart for seal sizes and cross reference numbers, they might carry it.
SEALS
/ Post Hole Digger Seals #4
Try a local bearing house.....Motion Industries or others.......
Common stuff.....
/ Post Hole Digger Seals #5
Common stuff.....
Yep, they cross the number or get it by size.
/ Post Hole Digger Seals #6
Yes, Definitely check with a local industrial bearing shop. They should be able to supply your needs.
