Post hole digger / auger question
   / Post hole digger / auger question #1
coolbrze
VA
Kubota MX5800
A friend of mine has an auger / post hole digger for his 35hp tractor. Can I run it on my 60 Hp tractor or will that damage the auger since I'm assuming they're rated for different HPs?
   / Post hole digger / auger question #2
pretty sure they mean AT LEAST x HP when they note HP to make sure the tractor can handle it
   / Post hole digger / auger question #3
Worst that can happen is you break a shear pin, or get it stuck in the ground. Bring a big pipe wrench with a long extension in case you need to reverse it out.
Thanks fellas from the Old Dominion!
   / Post hole digger / auger question #5
Just remember, you don't need a lot of horse power for digging holes...I run mine (12" auger) just above idle and it does great. BobG in VA
   / Post hole digger / auger question #6
BobG is absolutely right. Keep your machine throttled down and go slow into the hole. I always start the hole with a hand post hole digger to keep the auger from wandering and to keep the holes reasonably in a straight line. After a few holes youll figure out what you should and shouldnt do.
   / Post hole digger / auger question #7
Yep, Bob is exactly right, slow and steady is the best method for digging holes with a PHD
   / Post hole digger / auger question #8
I'm not a fan of running my auger at idle. There isn't as much power in the hydraulics to lift it out and clean the hole. I'm at 1,200 to 1,500 when I drill my holes, and sometimes I will step on the gas pedal to get even more RPMS for additional hydraulic power when needed.
   / Post hole digger / auger question #9
Here's what I use to clean out my holes after I auger them. It doesn't seem to matter what RPM I run, the auger never completely clears the hole of all the loose stuff. I gave up on those crappy clamshell diggers years ago.
Boston Digger
   / Post hole digger / auger question #10
Great! Another tool I have to buy.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
CASE MXM 190 (A58214)
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
